10-15-2018, 09:31 AM | #1 |
Rep 1,264
Music Collection issue
Car is a 2018 M240i with HK. I had my iPhone 7 connected to the audio system via the USB port and an apple cable. Had issues with songs not finishing before the next song would start. I switched to the music collection. The audio system worked fine. When I got home I decided I would update the music collection. I FAT32 formatted my Sandisc USB3 stick (16GB) and then loaded it with my music from the hard drive.
The first step I did was to delete all of the music in the music collection. I verified this by checking that all of the system’s memory was avail. I then inserted the memory stick in the car’s USB port and tried to load the music collection from the memory stick. The system couldn’t “see” the memory stick. I tried this several times, all to no avail. I then disconnected the negative cable from the battery and left it disconnected for 5 minutes. I reconnected the negative cable and tried to upload the music. Same result. Here’s the weird part: the system will play music loaded on the memory stick!!!! Thoughts?! |
10-15-2018, 12:30 PM | #2 |
Rep 366
Drives: 218i Coupe
Garage List 2020 BMW X2 [5.25]
1993 BMW 850Ci [8.33] 1990 BMW 316i [8.00] 1994 BMW 318i [0.00] 2000 BMW Z3 Coupe [8.83] 1974 BMW Alpina A2 ... [10.00] 1985 BMW 635 CSi [0.00] 2018 BMW X3 [0.00] 1975 BMW 2002 [5.50] 2016 BMW 218i Coupe [8.00] 2006 BMW Z4 M Coupe [8.67] |
Can I have your VIN please to check in the BMW system?
10-15-2018, 02:11 PM | #4 | |
Rep 366
Drives: 218i Coupe
Also PS: you have new map data (NA 2018-3) available for your car, try updating that with the USB to see if it will indeed read and update it or just no response Let me know how it goes... |
10-15-2018, 02:57 PM | #5 |
Rep 1,264
The car was in for it’s one year service. Doesn’t the dealer check these software updates when it has the car?
The gauge cluster software was updated about a month after I took delivery of the car in September 2017. I don’t think anything else has been updated. I’ll try the idrive reset to see what happens. I’ll get back to you with the results. I appreciate your help in this issue. |
10-15-2018, 03:22 PM | #8 |
Rep 1,264
Ok, started the engine and tried to reset idrive. I was able to reset idrive but no change-still doesn’t see the thumb drive when I try to upload music to music collection. Verified that it does charge my iPhone. Argh!
I’ll stop by thr dealer tomorrow and hand the SA a hard copy of the issue. I appreciate your help! |
10-16-2018, 03:41 PM | #10 |
Rep 366
Drives: 218i Coupe
Ok so at this point dealership is the best way to go. Only other suggestion I have is you can try to install the songs with another USB. BTW, don’t forget to tell your SA all the troubleshooting things that you’ve done including the ones above, it saves them a great amount of time and you will be treated as a customer that understands his car which, in turn, avoids hearing bs. Let me know how it goes...
10-18-2018, 03:47 PM | #11 | |
Rep 1,264
Thanks, Mark |
10-22-2018, 09:51 AM | #12 |
Rep 1,264
Took the car to the dealer and they found nothing. Well, except that I’m trying to upload songs the wrong way. I was using the “manage storage” menu. I should have been using the “import” method. Argh. Thanks for you help.
10-24-2018, 03:37 PM | #13 | |
Rep 366
Drives: 218i Coupe
we are all human, mistakes are allowed. I’m just glad you got it working |
