2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics Trunk power block plug
      10-05-2018, 09:44 PM   #1
skidplate
skidplate's Avatar
Drives: 2016 M235iX; 2020 X3
Adding an amp and sub, would like to tap my 4ga power cable into this power block in the trunk. Can't find any info on adding additional plugs in the empty slots. Has anyone figured this out? Could not find anything using the part number v6922775205 or searching these forums.
https://ibb.co/jm7GEK
https://ibb.co/hqbXoe
      10-06-2018, 12:32 PM   #2
Dirtboy
Dirtboy's Avatar
Drives: F87, F97
The part number for that distribution block is 61149227752.
If you look inside, it looks like fusible links are welded to the bus bar. If you blow one, you have replace the whole thing, I think...
I connected my 4 gauge cable for my sub amp to the positive lug to the left of the distribution block. I also added an inline fuse.
      10-07-2018, 08:41 PM   #3
skidplate
skidplate's Avatar
Thanks for the reply, and that information. I will find 12v somewhere less complicated.
