09-01-2016, 01:22 PM | #23 | |
Rep 1,541
09-01-2016, 01:23 PM | #24 | ||
Rep 893
2019 SG M5C
Anthony235715.00 |
09-01-2016, 01:24 PM | #25 |
Rep 1,541
Dark, even with 100oct and a small E mix you'll be limited to ~17psi?
09-01-2016, 01:25 PM | #26 | |
Rep 893
2019 SG M5C
Anthony235715.00 |
09-01-2016, 01:35 PM | #29 | |
Dejan
1753
Rep 4,197
Drives: 2018 Audi S3
Garage List 2013 BMW 335i [10.00]
2015 BMW 228i M Spo ... [0.00] 2013 Ford Focus (DD) [0.00] 2001 Alfa Romeo 156 [0.00] |
FBO-PS1 and stuff
09-01-2016, 01:37 PM | #30 |
Dejan
1753
Rep 4,197
That's pretty much all there is to it. One can do a ps2 around 16-17psi on 93 and net around 440-450whp and that's it. Going on words will take fueling upgrades and or meth/PI.
FBO-PS1 and stuff
09-01-2016, 01:47 PM | #31 | ||
Rep 390
There will be safer options than PI if one really cares and could wait. |
09-01-2016, 01:49 PM | #32 | |||
Rep 893
2019 SG M5C
09-01-2016, 01:50 PM | #33 | ||
Rep 893
2019 SG M5C
Anthony235715.00 |
09-01-2016, 01:59 PM | #34 |
Rep 1,541
Link to post?
09-01-2016, 03:18 PM | #35 |
Rep 1,349
Drives: BMW F80 M3
100 octane has same energy content as 93. So you still have to inject the same amount. EWG cars run a tad leaner than PWG cars but I would say around 17-18 psi is the limit. You may get away with more in lower gears but the higher gears will put more strain on the fuel system as well.
Anthony235715.00 |
09-01-2016, 05:55 PM | #36 | |||
Rep 647
09-02-2016, 08:40 AM | #37 | |
Rep 390
Starting page 33 half down Last edited by quattr0; 09-02-2016 at 08:53 AM.. |
09-02-2016, 08:48 AM | #38 |
Rep 390
As stated, "future" ;-) Kidding aside, DI, 2nd HPFP, etc. No known solution yet. I understand Terry is looking to update his firmware to prevent hyperlean as Mauricio pointed out. Do not kniw how effective it would be as Mauricio stated it only takes a second to destroy the piston in hyperlean condition. Read the link replied above.
09-02-2016, 10:26 AM | #39 | |
Rep 1,541
I hate adding complexity to any system, but PI is the only option right now. I would easily pay $1500 for a plug in play HPFP solution. I spent that much on my Z just to fix fuel starvation in right hand turns. |
09-05-2016, 01:54 AM | #40 |
Rep 1,349
Drives: BMW F80 M3
All supplemental fuel systems have their drawbacks. On N55 the DME does not cut the injector off easily when you get missfires. Usually they are small and can be felt. At this point you will release the pedal, cilinder wasnt cut off and nothing bad happened. If you keep pressing the pedal down the DME will eventually cut off the cilinder and engine will sound a lot different since it runs on fewer cilinders. At that point you would be stupid to keep the pedal to the floor. Even at the small misfires make a habbit of letting the pedal go. Nothing bad happens.
I dont know why BMW made this change on N55 vs N54 cutting off DI from 1 cilinder. On N55 it doesnt happen a lot and comes with warning first. Our cars missfire when HPFP goes under 10 in the logs. On N54 they get more heavy missfires but only when HPFP drops to under 5. I think hence the immediate cut-off. On N55 it's of less concern imo. |
Anthony235715.00 |
09-05-2016, 01:23 PM | #41 | |
Rep 1,084
IMHO: the ship has sailed. All roads to more power on an N55 go through PI.
Anthony235715.00 |
09-06-2016, 11:10 AM | #42 |
Rep 1,541
Wish we could just throw a Walbro and bigger injectors in and call it a day!
09-06-2016, 12:45 PM | #43 | |
Rep 1,349
Drives: BMW F80 M3
Luminous743.00 |
09-06-2016, 01:52 PM | #44 |
Rep 1,541
I know. Just saying I wish it was that easy.
