2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum BMW not covering bent rim
      11-28-2018, 01:36 PM   #1
Asw71192
Drives: 2018 M240xi
Last week I hit a pothole which damaged my driver and passenger side front tires. Tears in the sidewall and some light rim damage. I have the bmw tire and rim package including cosmetic so I took my car in to the dealer to have the tires replaced and rim repaired. Got a call from my dealer that the rim is slightly bent and they can't get it to balance, however they will not be covering a replacement because the rim is not bent enough to be leaking air. Has anyone had this issue and recommend what I can do? Seems unfair that I paid for the insurance and they are not covering the damage because it's not severe enough by their standards.
      11-28-2018, 01:59 PM   #2
overcoil
Drives: M235i 6spd
will u say which dealer ? is there a written contract to quote from ?
is the dealer saying the wheel is good enough that you can use it as is or is the dealer recommending a new wheel ?
I just read the BMW wheel tire warranty on line where it says 'prevents tire from sealing to wheel' - damn that's pointless. Is there additional text in the warranty you signed ?
      11-28-2018, 02:32 PM   #3
tennisfreak
Drives: M240i
Easy fix: take the car for a drive and find a bigger pothole.
Appreciate 4
      11-28-2018, 02:41 PM   #4
Ron Jeffries
388
Drives: 2018 M240i xDrive convertible
Yes, the wheel and tire coverage fine print says the wheel has to be unusable before they'll replace it. The technical term for this is "bullshit".
CP911986.50
      11-28-2018, 03:17 PM   #5
hwntime
hwntime's Avatar
272
Drives: F22 Raptor
If you have cosmetic coverage, why not just go and curb your wheel with a huge scrape. At that point, they'll have to pay for the repair and since it's already bent, it would make sense to just replace it.
      11-28-2018, 04:36 PM   #6
USA-RET
USA-RET's Avatar
605
Drives: Estoril Blue M240i
Fricking "mice type". Always the case, even w/ extended warranties.
      11-29-2018, 04:54 AM   #7
morphomeman
morphomeman's Avatar
593
Drives: 2015 M235ix
2016 BMW X3  [0.00]
2015 BMW M235ix  [0.00]
I don't get it. If they can't get the wheel balanced, then it is unusable, no?
I have the package and have used it several times on both wheels and tires, to the point where it has paid for itself, but I have never had enough wheel damage to warrant replacement, only cosmetic repair, which has always been very well done.
In all likelihood, the insurance is not through BMW but through a third party. Get out your contract, call the number, and talk to someone at the insurance company.
      11-29-2018, 05:48 AM   #8
vwcrusher
Drives: 2017 M240i xdrive
I had a similar experience last winter; went through a pothole that was filled with water...no idea how deep it was. Ended up splitting the right front wonderful RF tire. The dealer replaced the tire (my cost - no insurance) and showed me the bent wheel. He suggested sending it out to have it straightened. It worked.
I strongly suggest that method before buying a new wheel. GL.
      11-29-2018, 05:56 AM   #9
Asw71192
Drives: 2018 M240xi
Thanks. I read the fine print and it does in fact state they only cover rim damage beyond the tire not being able to seal to the rim. It's bullshit, but I guess that's how this game works for them. Going to go with the straightening path and hope that works out for me. $1xx odd dollars seems like a better deal than the $500 quotes for the gloss black 719m rim.
On the bright side this wheel and tire package has now covered 4 tires in the first 12 months of ownership. So feel there has been some value out of it.
      11-29-2018, 11:04 AM   #10
Luftwaffe1O1
Drives: M235i, 2000 Z3
Just fyi discount tire also has a tire warranty for about 20-30 per tire. It sounds like you would have to completely destroy a rim for the bmw warranty to take effect, but not sure how this is helpful, as damage that severe you can probably use your car insurance anyways.
      11-29-2018, 01:27 PM   #11
morphomeman
593
Drives: 2015 M235ix
2016 BMW X3  [0.00]
It is important to realize that these warranty packages do not come from BMW. The dealer is a broker for an insurance company and the packages differ from insurer to insurer. OP clearly got a lousy package, which apparently does not cover cosmetic damage. A good package will run close to $2000 for 5 years, but it is worth it if you take the rims in regularly for cosmetic repair. And yes, these cars eat tires, especially the 19" rims.
      11-30-2018, 11:51 AM   #12
amw896
amw896's Avatar
Drives: 2015 BMW M235i
2015 BMW M235i  [10.00]
grab a sledge and crack it. Drop it off again and say here u go.....
what a bunch of scammers...
      11-30-2018, 05:34 PM   #13
Poochie
Luxury at the redline :)
Poochie's Avatar
Drives: 2016 M2
It's not easy to break with a hammer, you'll need an air impact chisel, if you want to keep your wrist intact ..
Or so I've heard
