08-12-2017, 09:22 PM | #23 |
Rep 5,262
08-12-2017, 09:41 PM | #24 |
Rep 716
Drives: F90 M5
Yea thats why im confused lmao
(Sold) M235I Dinan intake, Active Autowerke FMIC, meisterschaft, TCKline coilovers, NT01's, BMS Oil cooler valve, VRSF DP&CP, BM3,StopTech Trophy BBK, Corbeau FX1 Pro seats, AP bar, Bimmerworld V3 Wing, APR Front splitter, Seibon Vented CF Hood
399.8whp on 91oct Hmu on Ig: @n55_shayan |
08-12-2017, 10:26 PM | #25 |
Rep 221
so mine did the same. ur prob hitting the kick down button at the base of the throttle. even tho I had mine in manual etc mine still kicked down. as far as I know u have to go hard on the throttle untill just before the button.
any one confirm? |
Shayan55338.50 |
08-12-2017, 10:28 PM | #26 |
Rep 716
Drives: F90 M5
Know for next time haha
08-12-2017, 10:29 PM | #27 |
Rep 73
Mine did the same - I suspect it is something to do with the fact the car detects the front wheels aren't moving and responds differently
08-12-2017, 10:44 PM | #28 |
Rep 221
it's really frustrating and if u go to a place that hasn't dynoed bms before they have no idea it seemed.
I didn't have dsc turned off tho so not sure if that helps but for me I was in manual shift and sport+. I imagine it would take some practice to get it just right before the kick down as if ur to cautious you could be not getting the Max out of the run. also: is 5 or 6 the gear of preference with runs? I thought 6that is the 1:1?? |
Shayan55338.50 |
08-12-2017, 11:21 PM | #29 |
Rep 1,931
in 8sp, 5th is 1:1 per terry at bms.
www.nybmwcca.org
Shayan55338.50 |
08-13-2017, 10:07 PM | #30 |
Rep 102
He still Dyno's in 4th gear, go figure!
15' X5M DG, enzotune
17' M2 *** CTS Turbo FMIC, CTS Turbo DP, CTS Turbo CP, CTS Turbo Intake *** Bootmod3 E30 OTS |
08-13-2017, 11:32 PM | #31 |
Rep 716
Drives: F90 M5
Lmaoooo
FSociety3812.50 |
08-14-2017, 11:31 AM | #32 |
IG @bmwF9xG80
3813
Rep 7,592
I think most 6MT guys dyno in 5th,8AT dyno in 4th or 5th it makes little difference according to what I've seen him say. Also, it will vary some Dyno Operator or Tuner prefer a certain gear.
Automatic gear ratios – IV/V/VI1.67 / 1.29 / 1.00
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
08-14-2017, 02:43 PM | #33 | |
Rep 716
Drives: F90 M5
08-14-2017, 04:41 PM | #34 |
IG @bmwF9xG80
3813
Rep 7,592
If its just 3 or 4 pulls do 5th gear first and try the next one in 4th to see if any difference on that dyno. Also, depending on Tune it could make more or less on the different gear.
For 1hr+ Dyno pulls, 4th is better cuz u heat soak less. Btw, read over your thread and makes no sense DSC OFF + Shifter to left like others have said then driving slowly as you reach 30-35mph shift up to M4 should Dyno operator should start WOT at 2500rpm and let it redline 6900-7k
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 Last edited by FSociety; 08-20-2017 at 06:50 PM.. |
08-14-2017, 04:44 PM | #35 | |
Rep 716
Drives: F90 M5
08-14-2017, 06:46 PM | #36 |
Rep 1,117
Drives: 2015 BMW M235i
The dyno guy recommended 4th gear for me but you're right, on a 6spd the 5th gear is 1:1. Does that mean my numbers are inflated?
08-14-2017, 09:20 PM | #37 |
IG @bmwF9xG80
3813
Rep 7,592
Your numbers are probably lower than that, you can give it a shot in 5th gear.
08-19-2017, 05:39 PM | #38 |
Rep 716
Drives: F90 M5
So i ended up going somewhere else to dyno. And they actually got it right haha. The first 2 pulls were on the enzo map. And the last 2 on the stock map for comparison. Ended up with 398whp!!
amw896582.50 |
08-19-2017, 07:02 PM | #39 |
Rep 1,931
really low tq, but great hp.
www.nybmwcca.org
08-19-2017, 07:10 PM | #40 |
Rep 716
Drives: F90 M5
08-19-2017, 07:37 PM | #41 |
Rep 1,931
great gains from stock... get some octane to boost up the tq.
www.nybmwcca.org
08-19-2017, 07:45 PM | #42 |
Rep 716
Drives: F90 M5
Yea that was on 91 pump gas. Frickin cali lmao
08-20-2017, 11:17 AM | #43 |
Rep 5,366
