11-18-2022, 08:15 AM | #1 |
Rep 6
Looking for exploded diagram of the front end.
I've recently found my car to have a very botched repair job from a bodyshop, not being the original customer that dealt with them I'm essentially being stonewalled.
I've got a new headlight on the way but noticed a fair bit of sag, my assumption is a few mounts / brackets are missing but can't find any diagram to indicate what should be there that isn't. It's a 2018 m240i LCI if this helps. Cheers. |
11-18-2022, 08:30 AM | #2 |
Rep 1,264
11-18-2022, 09:30 AM | #4 |
Rep 1,794
They look to be on the light sub-assembly diagram. https://www.realoem.com/bmw/enUS/sho...diagId=63_1899 Grommets, Set Mounts, Alignment Element
Maybe they were tossed with the original and forgot to replace them? |
11-18-2022, 09:33 AM | #5 |
Rep 6
I've seen these mounts and have ordered some, but it's more so what they connect to. From when I've had the bumper off and seen the problem one of the top metal mounts was mangled (now replaced)
But it still seems to sag, so I'm assuming there's some sort of metal bracket that holds it in place but I can't see one in any diagram. I may just have in my head it needs one where it actually doesn't, I'll need to have another go with the bumper and compare the left side (damaged) to the right (undamaged) |
11-18-2022, 09:50 AM | #6 |
Rep 1,794
Could try looking up a DIY vid like this (first couple minutes are relevant... this is for the 3 series but likely similar)
To see what mounts to what. |
