10-13-2022, 03:48 PM | #1 |
Rep 16
M-Sport Rotor Size/Pistons
I've been modifying my 2018 M240i X-Drive I picked up a couple months ago and when I went to upgrade the rotors, I saw on a site that I can tell I have the M-sport brakes by the 2 piston caliper in the rear. The difference being 340mm vs 370mm?
My original window sticker says M-Sport brakes. I have Blue M calipers, SINGLE piston in rear, 2 piston up front. Is there a M-Performance brake out there as opposed to the M-Sport I have? I know I can just pull a wheel and measure, but I wanted to know if there are different packages I did not know about?, mm size, etc. as it may push me to consider a different brake set up altogether. I just AutoX and occasional track day so I don't need massive brakes, but I'm going to be pushing 500-525hp to the wheels, so a brake upgrade at some level is prudent. |
10-13-2022, 09:14 PM | #3 |
Rep 16
OK, Got it.
That's not how I am used to thinking about calipers. Two piston would be 2 opposing 'sets' of pistons. To operate the inside pad, there has to be an opposing piston. So using that logic, the fronts are 4 piston calipers. So the M-sport brakes are 370mm rotors. |
10-13-2022, 09:21 PM | #4 |
Rep 1,014
No, the blue M-Sport calipers have the 340s. Lots of discussion of this in the chassis forum.
https://www.2addicts.com/forums/forumdisplay.php?f=522 |
10-13-2022, 10:00 PM | #5 |
Rep 16
No wonder there so much confusion about this. Doing more digging, I found this:
https://www.bimmerworld.com/About-Us...-Brakes/#M235i There's M-sport, then there's M-Sport S2NHA base (M Sport) 340x30mm, blank S2NHA M Sport/ZTR 370x30mm, blank Maybe I should go back to my Porsche's.... :-) |
10-13-2022, 11:30 PM | #6 | |
Rep 5,262
10-14-2022, 08:20 AM | #8 |
Rep 5,262
10-14-2022, 09:43 AM | #9 |
Rep 913
There are also adapters to allow you to keep the 340mm brake calipers but run the 370 / 380 mm rotors.
Rogue Engineering SSK & transmission mounts, WaveTrac LSD. Ohlins R&T coilovers, Turner monoball thrust arms, F87 LCAs, GC camber plates, Superpro subframe bushings, Megan Racing adj. RCAs, delrin differential bushings. Stoptech BBK 6 piston (f) 4 piston (r). |
10-14-2022, 01:10 PM | #10 |
Rep 16
That's what more digging revealed. From what I gather they could be swapped into the 2 series. But I'm not willing to go that far until there is a real issue after I put the slotted/drilled rotors, appropriate pads/fluid into play.
10-14-2022, 01:11 PM | #11 |
Rep 16
10-15-2022, 06:35 AM | #12 |
Rep 48
If you're running 18" wheels, the 370mm rotors may be too tight.
Kern417 used to have the brackets available on F30/31 forums. Learn from my mistake -- I recently replaced rotors/pads. I have the S2NHA option on my VIN sheet and blue rotors. Didn't pull off the wheel and measure, just ordered the 370mm from what I could see online. Was up on the lift with rotors detached, pads out, and everything apart before I decided to line up the new/old rotors. Thankfully Turner Motorsports didn't charge RMA shipping. |
10-15-2022, 01:30 PM | #13 | |
Rep 3,496
Bimmerworld asserts "massive caliper clearance" for its 17" TE:AL TA16 forged race wheel, leading me to wonder if that 17" wheel might possibly fit over the M Performance kit's calipers. Wouldn't that be something!
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9½ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro; GTechniq Crystal Serum Ultra Ceramic; Suntek PPF Last edited by dradernh; 10-15-2022 at 05:25 PM.. |
10-15-2022, 09:12 PM | #14 |
Rep 16
Thanks for the link. I was planning on staying with the 18" rims, using the factory rims for winter, then in the spring going new rims/+2 tires.
Went autocrossing today and found out you CAN do a 4 wheel drift on a AWD car :-) |
10-20-2022, 04:47 PM | #15 |
Rep 16
Just a quick update, talked to Kern417. I ordered the adapters to run the 380mm rotors. He said they will fit the factory 18' wheels with a 5mm wheel spacer.
I may not do this till spring, I've only had the car for 2 months and I've already done the DP, Intake, TU pump, JB4 tune w/FSB, Meth injection, and xHP trans tune. I should have the Vargas GC turbo install done in the next day or two. Not to mention the splitter, spoiler, diffuser, and other misc. mods. I've been busy... |
WolfGTI716.00 |
10-24-2022, 05:24 PM | #16 |
M-Poser
70
Rep 56
I'm still figuring out the best route for my m235i, but this article gives a good explanation:
https://www.bimmerworld.com/About-Us...-Sport-Brakes/ |
11-10-2022, 03:56 PM | #17 |
Rep 7
Hi,
I'm planning on replacing my front rotors and pads and had two questions... Is it OK to reuse the caliper to wheel mounting bolts? Does anyone know the torque setting for those bolts? Thanks! |
11-10-2022, 07:22 PM | #18 | |
Rep 442
Front caliper torque: 110 Nm The bolts are fairly cheap though. ~$6 each. So I did replace them when I did mine. M12x1.5x43 ZNS3 , 2/caliper, P# 34106864424 |
11-15-2022, 03:54 PM | #19 | |
Rep 7
11-15-2022, 08:25 PM | #20 |
Rep 442
I bought them from FCP Euro:
https://www.fcpeuro.com/products/bmw...nt-34116772117 But this is the kind of small part where a dealer isn't outrageous especially after you consider shipping. And they are available at tons of other places online. Just google the part number. |
