2Addicts | BMW 2-Series forum Technical Topics N20 (228i) / B46 (230i) Engine, Transmission, Exhaust, Tuning Check engine
      09-13-2022, 01:26 AM   #1
J555rt
Drives: 2014 Bmw 228i 6mt
Check engine
Code p10f4 is popping up. Any idea on what it is?
      09-22-2022, 08:15 AM   #2
nazali
nazali's Avatar
Drives: 230 2020 vert F23
the power of google
P10F4 BMW Code - Valvetronic Control Phase U Circuit Open Bank 1
Visually inspect the related wiring harness and connectors. Check for damaged components and look for broken, bent, pushed out, or corroded connector's pins.
      09-27-2022, 02:25 PM   #3
J555rt
Originally Posted by nazali View Post
the power of google
Thanks smart google user😂😂 gave me the most basic answer. Obviously I checked google but was looking for something a little more elaborate
      09-27-2022, 02:45 PM   #4
nazali
nazali's Avatar
Install and use Ista and it will diagnose that for you, it will also run a test plan, give you wiring diagrams.
You also didn't say what you had or hadn't done.
Always best to tell us your level and what you have done.
If your using a basic OBD device on a BMW instead of Ista kinda tell's me where your at.
The error is saying there is an issue with the harness, either open or short circuit, but of course it could be a number of things which is why you need to run a test plan with ista and or break out a DVM, again, were looking at a pic of you holding a OBD2 device asking what is this, with no other info ?
Also you still haven't said what you have or haven't done, so, I'm still one the wiser
Originally Posted by J555rt View Post
Thanks smart google user���� gave me the most basic answer. Obviously I checked google but was looking for something a little more elaborate
