2Addicts | BMW 2-Series forum Technical Topics B58 (M240i) Engine, Transmission, Exhaust, Tuning Check engine light when pressing BC/resetting speed
      07-22-2022, 03:49 AM   #1
BMW335l
Drives: M240i, GTI MK5, Corolla TTE
Hi,
Today when driving I long pressed the BC button to reset the fuel consumption and average speed. The check engine light started blinking and the rev counter stopped and was stationary on 0 and 1, (toggle between 0 and 1 if BC was pressed again). The blinking check engine light disappeared when long pressing the BC again. I replicated the issue twice. Any idea?
      07-22-2022, 07:53 AM   #2
marcthedark
Drives: M240i xdrive Convertible
Do you have an MHD/BM3/... map?
      07-22-2022, 08:25 AM   #3
BMW335l
Yeah I have MHD flashed.
      07-22-2022, 11:49 AM   #4
marcthedark
That might be some MultiMap etc switching method.
MHD+ Menu System
On supported MHD+ platforms (currently F/G-Series), entering into “mapswitch” mode is not
only just for mapswitch. It is actually a more advanced paged menu system, with 3 different
“pages” as of current release. You enter into the menu system the same way you did mapswitch
(F/G-Series: press and hold either the cruise control SET/LIM button or the BC button for 2
seconds). You will always enter on “page 1”, which is designed by a pattern of one CEL blink at
a time.
To change pages, quickly press the SET/LIM button or the BC button. The current page is always
indicated by the blink pattern of 1 / 2 / 3 blinks in a row. To exit the menu, press and hold again
like you did to enter. Page details are as follows:
Page 1 - Mapswitch
This is the normal map switch you are used to. UP/DOWN on the cruise control rocker will move
the RPM tach to your desired map selection. If you only have 1 active map slot, you will not be
able to move the tach from 1000 rpm. You will still have access to page 2 and 3 though.
Page 2 - Exhaust Flap Control
Page 2 allows you to control your vehicle’s exhaust flap on the fly. There are three settings you
can switch between (again using the UP/DOWN rocker).
● 0 rpm = OEM exhaust flap control, no forced override
● 1000 rpm = exhaust flap always forced open
● 2000 rpm = exhaust flap forced closed (note: this will only apply up until a certain load
threshold for safety)
Page 3 - Ethanol Content Quick View
Page 3 will show the current Ethanol percentage of your fuel (when using an appropriate
CANBUS ECA kit). 1000rpm = 10% Ethanol, up to 7500 rpm = 75% ethanol. If you need to see
E% greater than that, you should log it or place it on an MHD Monitor gauge.
      07-22-2022, 12:25 PM   #5
BMW335l
MHD+ Menu System
a time.
Page 1 - Mapswitch
Thanks man, this is definitely it. They mention that the CEL blinks and that you exit with the BC. I was hoping it was something like this!
