07-07-2022, 08:58 AM | #1 |
Rep 13
Recent Purchase 2017 M240i
Hey all,
I recently purchased an M240i from a local friend. As far as I knew the only changes were some cosmetics (carbon side mirror covers, reflector covers, start/stop button) and a BMS intake. However, he just mentioned he also had the car tuned with a Eurocharged stage 2 tune. I contacted Jerry at Eurocharged and he informed me that the vehicle was tuned conservatively with around 60HP/50TRQ. My question is this: Should I trust this tune or just go the typical route with an upgraded high flow catted downpipe + BM3 stage 1/2 93? I was told long ago to never trust a car you didn't tune yourself or witness being modified. Was wondering what experiences you guys have had with Eurocharged tunes on similar vehicles. Thank you! |
07-07-2022, 12:12 PM | #2 |
Rep 452
I havent heard of anyone in the groups who runs that shop's tune, if that says anything to influence your decision.
I wouldnt want support/questions limited to one guy either. |
07-07-2022, 12:21 PM | #3 |
Rep 13
Thank you that makes sense. New to BMWs so wasn’t sure if it would be safe to just tune with BM3 and xHP or if I’ll need to tune to stock first. I agree with your logic.
07-07-2022, 01:15 PM | #4 |
Rep 409
It is a Stage 2 tune without a downpipe? Why would anyone do this and claim it was conservative (as Stage 2 without DP is not recommended aka not conservative).
07-07-2022, 01:22 PM | #5 |
Rep 1,117
Go with the tune and setup that you want to do. I wouldn't like/trust a previous tune unless I was forced to keep it (had no money, wife wouldn't let me, etc) and I could see clean logs showing solid performance and no safety issues. Upgraded DP and either of the most common flashtunes BM3 or MHD are the way to go in my opinion.
2024 M2
2019 M240i- Sold |
07-07-2022, 01:36 PM | #6 |
Rep 13
Right... my understanding is just the air intake which didn’t make sense to me either. I don’t have the means to jack the car and verify stock DP. Anyone know of another way to be sure? Otherwise I’ll have to run down to a shop. Sounds like I’ll just grab a catted DP (if still stock) then flash with BM3 stage 1/2 93. I just worry I won’t have a stock tune back up at that point.
07-07-2022, 01:38 PM | #7 | |
Rep 13
JMcLellan1944.00 |
08-24-2022, 11:21 AM | #8 |
Rep 87
Eurocharged isn;t bad for their tunes at all pretty good , if you want something you can adjust yourself and turn off and on, switch to a flash tune for MHD or bm3 map
2015 F30 335XI PS2 FBO SOLD
2017 F22 M240i xDrive |
08-24-2022, 06:19 PM | #9 |
Rep 908
Stage 2 to different tuning places means different things - their stg 2 may not necessitate a downpipe, considering it is only 60HP.
Rogue Engineering SSK & transmission mounts, WaveTrac LSD. Ohlins R&T coilovers, Turner monoball thrust arms, F87 LCAs, GC camber plates, Superpro subframe bushings, Megan Racing adj. RCAs, delrin differential bushings. Stoptech BBK 6 piston (f) 4 piston (r). |
