12-31-2021, 12:51 AM | #1 |
Rep 4
Have a weird gremlin..
I have a 2015 M235i with 39k miles and I've had an issue that I haven't had any luck getting rid of. I'm wondering if anyone else has some input or experience with this.
Code: 1D2008 map-controlled thermostat: stuck open The radiator fan will blow at high power and extremely loud. The oil and coolant temps don't get much higher than 160f even after about 20mins driving. I have had the thermostat and coolant temp sensor replaced with no luck. I can't seem to get rid of this issue, can anyone else share some insight or help? Thank you. |
12-31-2021, 02:31 AM | #2 |
3626
Rep 3,593
Has the wiring to the thermostat and temp sensor been checked for damage? A charge pipe change could cause damage to the wiring or connector, if not done carefully, if that has been done on your car in the past.
12-31-2021, 09:41 AM | #3 |
Rep 5,369
12-31-2021, 02:52 PM | #4 |
Rep 142
I had this issue and it still occured after replacing the thermostat. It ended up being that the coolant level was just low enough so I filled it to the max line and all was well. So moral of the story is to check the simple things first.
12-31-2021, 05:53 PM | #5 |
Rep 4
Thanks for the input guys, I'm going to start with the coolant level first. My driveway has pretty steep slope to it so I just pulled the car out and will let it cool a little.
I haven't even looked at the wiring but I'll check that out next. According the the TSB the only thing left would be the auto trans heat exchanger. I had a shop look at that recently and they said it was functioning properly so if none of the options above help I'll take it somewhere to have it swapped. |
01-01-2022, 01:35 PM | #6 |
Rep 4
Update: Coolant level was at max. Not experienced enough with electrical to know where the connections are but I will look there when I have some more free time.
Happy New Year people! |
01-10-2022, 02:32 PM | #7 |
Rep 4
Another update:
Took the car to a buddy who's a BMW tech and looks like the trans cooler is working fine too. He found the engine harness is in bad shape and has some Mickey Mouse "repair" to it. I just got the car a couple months ago so possibly a remnant if the previous owners handy work. |
10-02-2022, 11:10 PM | #8 |
Rep 3
Were you able to figure out that is was the wiring harness? I've been chasing this problem for years and you have the same year/car as me. Any help would be great!
