09-18-2021, 01:06 PM | #1 |
Rep 15
481WHP Stock Turbo M235i
Greeting y'all I just wanted to show the results of my most recent Dyno test.
The mods VRSF- Downpipe & Chargepipe BMS- Intake CSF- Intercooler GFB- Diverter Valve Fuel It Stage 2 LPFP Dorch Stage2 HPFP NGK- spark plugs Bootmod3 Custom E85 tune by Jordan that pushes around 18.5 pounds of boost Note: I do have a boost leak you can see it at the tail end of the graph when my power starts to fall |
09-20-2021, 08:42 AM | #3 |
Rep 190,777
do you have baseline numbers?
09-20-2021, 10:57 AM | #4 |
Rep 5,369
Dynocom dynos compute power numbers to whp and wtq. Dynocom dynos read quite a bit higher (~15%) than a Dynojet dyno. On a Dynojet (which is the dyno most use), the numbers would be around 410-420whp and 450-460wtq which is about what I'd expect for the mods and an ethanol tune and stock turbo.
09-20-2021, 11:22 PM | #6 | |
@_sunbish
282
Rep 611
Without a log or knowing how much timing, it's hard to believe 480/540+ on the stock turbo at 18.5lbs of boost.
'14 435i RWD - BM3 stage 2+ E30/bolt ons/stock turbo/full drag pack -- [10.9@125].....60 to 130 - 8.5
'16 340i RWD - BM3 stage 2+ E50/bolt ons/stock turbo/full drag pack -- [10.2@131]......60 to 130 - 7.5 |
09-21-2021, 06:17 PM | #7 | |
Rep 15
09-21-2021, 06:21 PM | #8 |
Rep 15
Yes stock the car made around 310whp and on a stage 2 E-30 tune the car made 403whp I also ran the E30 tune with full E and upgraded pumps and it made 413 whp and 500+ torque
09-21-2021, 06:26 PM | #9 | |
Rep 15
09-21-2021, 06:44 PM | #10 | ||
Rep 15
This is the last log I sent to my tuner it is a street tune |
09-22-2021, 06:42 AM | #11 |
Rep 415
Your map certainly runs more timing than any OTS. The closest OTS map to your custom map is probably BM3 e30 stage 2+ which runs 21 psi and 13 degrees of timing.
The log above shows you running 18 degrees of timing with a target of 18.5psi of boost. It would be interesting to see a bit more boost with the higher timing. There’s definitely room for more power over the stage 2+ OTS IMO. |
09-22-2021, 09:05 AM | #12 |
Rep 190,777
Nice
09-24-2021, 02:23 PM | #13 | |
Rep 643
and you made 481 whp with the custom tune? do you have any logs when running the ots tune for comparison? how would you compare the 2 tunes?
M235i rwd 6mt
09-26-2021, 03:23 PM | #14 | |
@_sunbish
282
Rep 611
At your peak hp ~5100rpm, there's only 9.5 degrees of timing and 18.5lbs of boost, at peak torque you have 7 degrees of timing and 20.6lbs of boost. The max MAF HFM you hit is about 40.2 on one pull. For comparison the stage 2+ is at 11 degrees of timing and 19lbs of boost at 5100rpm, at 4000rpm its at 9 degrees of timing and 21.5lbs of boost, and maxes out the MAF HFM at 41.3. I'm not saying there isn't a gain to be had over the stage 2+, but I'm having a difficult time believing that dyno isn't inflating numbers. Last edited by 5w20; 09-26-2021 at 03:41 PM.. |
10-01-2021, 10:51 AM | #16 |
Rep 124
Just leaving this here, take it with a grain of salt https://www.instagram.com/p/CEmxnj-g..._web_copy_link
IG @jq_f22
10-01-2021, 10:53 AM | #17 | |
Rep 124
Is that your ots+ log you're refrencing? I would like to see if you want to pm it!
IG @jq_f22
10-05-2021, 02:36 PM | #18 | |
@_sunbish
282
Rep 611
https://www.bootmod3.net/log?id=615c...90c67c64a9cf7e you don't mind sending me one of yours? I'm interested in seeing what yours looks like. Last edited by 5w20; 10-05-2021 at 02:44 PM.. |
10-14-2021, 07:44 AM | #19 | |
Rep 124
IG @jq_f22
10-14-2021, 12:17 PM | #20 | ||
Rep 15
10-14-2021, 12:21 PM | #21 | |
Rep 15
10-17-2021, 08:44 PM | #22 |
@_sunbish
282
Rep 611
