04-02-2021, 06:35 PM | #1 |
Rep 515
Squeaking sound
So, I have noticed on some occasion on and off when I entered the car a squeaking sound. I have tried bouncing up and down in the car and couldn't reproduce it. Today I realized the sound come if I push the car to the side. It doesn't sound too bad that would make me worried, just wanted to know if others had heard it too and its normal?
04-02-2021, 06:46 PM | #2 |
Rep 5,577
R U hearing it when u go to sit down in the car ? if it's a squeal when your weight hits the seat it could be the emergency brake.
I think I read that a few times a years, use the emergency brake to slow the car to a stop from a speed of about 5mph (?) to burnish corrosion of the surfaces. Last edited by overcoil; 04-02-2021 at 06:57 PM.. |
04-11-2021, 10:13 PM | #4 | |
Rep 515
I tried the emergency brake to slow car to a stop thing and it didn't work. Im just gonna ignore it, a friend of mine say its normal too. |
04-12-2021, 06:55 AM | #5 |
Rep 1,797
I'm not saying it is or isn't this... you may need a friend to help troubleshoot the location of the squeak.
https://www.e90post.com/forums/showthread.php?t=1274388 I had to replace the spring perch to hub bushing on my e90 and it went away. Similar drawing to ours... #3 as well https://www.realoem.com/bmw/enUS/sho...diagId=33_1602 Recommended to try some soapy water on just that bushing and see if it goes away temporarily. |
11-11-2022, 06:38 PM | #6 |
Rep 29
What was the solution? I’ve had a sound more like chirping seems to be coming from the back. I tought it was the bushing #3 as well . I have a 2017 m240i convertible . I can’t seem to find the issue . I added grease to all the bushings but noise persist. I can’t reproduce the sound by moving the suspension. Any help appreciated
11-16-2022, 08:14 AM | #7 | |
Rep 515
On a separate note.. new squeak which might be from my suspension came up... I hear it whenever the car is coming down from going over a bump or whenever it went on a slope or a dip unevenly... More like creaking.. urgh |
