05-11-2015, 01:28 AM | #1 |
Rep 4
Lower back pain
Hi
Been browsing these forums for a while and cant find a thread on my problem. I picked up my M235i last week Monday and since then I've had horrible lower back pain. I've tried changing the seating position a number of times without any difference. Other than that, loving every aspect of the car, having so much fun I've never been a person that's ever experienced any kind of major back problems that last more than a couple of days which is rather puzzling. I've got the standard leather seats with power adjustment. I did not get lumbar support. Has anyone else experienced a similar problem or got a suggestion? |
05-11-2015, 05:01 AM | #2 | |
Rep 13
05-11-2015, 05:22 AM | #3 |
Rep 709
I can't comment on the 2 series seats as I haven't bought one yet but I suffer from lower back pain and I've discovered what sets it off are seats which have a base (the bit you sit on) which tilts downwards at the rear end. This is often found in cheap cars when you want to sit as low as possible. I sincerely hope this isn't the case with the BMW seats. In more expensive cars the base remains horizontal but just goes downwards when you push the lever.
2011 Lotus Elise SC, 2002 BMW 330d, 1990 Caterham Super 7 HPC (sold), 1985 Porsche 911 Carrera SC (sold), 1978 Caterham Super 7 (sold), 1972 Triumph TR6 (sold), 1972 Jensen Healey (sold), 1965 Triumph TR4A (sold)
05-11-2015, 05:28 AM | #4 |
Rep 404
If the car is new, then give it a few more weeks. I have this problem every time I get into a new car. A part of my back is always in pain. Then, by magic, it goes away...but that takes a long time.
I'm no expert but my theory is that it's a form of muscle ache. With every different seat, you are working different muscles that may have been inactive for a long time. |
05-11-2015, 05:44 AM | #5 | |
Rep 761
Drives: M235i Coupe
market if its any consolation. |
05-11-2015, 07:13 AM | #6 |
Rep 5,577
Sorry to read about the back pain.
There are a few articles or excerpts from books recommending how to adjust the drivers seat (Vic Elford, Bob Bondurant). I know its about personal comfort but things like distance from brake pedal and not locking out your knee on brake pedal depressed or the seat back angle so that your wrist is comfortably situated on the steering wheel at 12:00 with your shoulders against the seat back as you play around with adjusting your position. Even rear view mirror or side mirror adjustment can cause neck strain if not taken the time to adjust properly. There are some articles about side mirror adjustment and how rear view mirror shoukd fill in the gap with eye glance instead of head neck manipulation. And the cars separate lower back and lumbar adjustment - playing with those didn't help? |
05-11-2015, 07:37 AM | #7 | |
Rep 1,797
What were you driving before? Context could be everything...I came from an X3..Going to an M235i was a huge adjustment for my back. How you get in and out of the vehicle, how you sit...All of those things..
Previous Rides: 535xi, M235xi, X3, E92 M3, E70 X5 35d, X6 50i, X6 35i, E60 550i, E46 M3 Cabriolet, E39 540i, E36 328i
05-11-2015, 08:00 AM | #8 |
Rep 1,756
Had the same problem in my 335d which didn't have lumbar support, the 435i and M135i both have it and it seems to make all the difference in my case, I'd never buy a car without it again
05-11-2015, 08:19 AM | #9 |
Rep 678
I had issues with my previous car after 30 mins or so of driving lower back pain would kick in, just could never get the seat right. M235i solved that problem, I do have the lumbar support.
2022 M4 Comp X 2021 M440ix - Sold 2015 M235 - Sold |
05-11-2015, 08:24 AM | #10 |
Rep 3,331
Have you tried adjusting the seat base angle to see if it improves the comfort?
I would not wait weeks to see if the discomfort goes away. If it's specifically your lower back then that's a concern without having the lumbar support. Does the 235i in SA not include lumbar support standard?
Current: '20 X5, '18 M3 ZCP
05-11-2015, 08:29 AM | #11 | |
Rep 2,802
You would think a BMNW would have Lumbar support standard. I didnt even think about it on my last one and it wasnt so equipped. Brutal IMO. |
05-11-2015, 08:47 AM | #12 |
Rep 1,219
Drives: 2015 M235ix
I had some pain at first with my M235. Solution: sit closer than you might think you should (wrists on wheel at 12 o'clock as already suggested); sit higher (fist-distance from roof); seat should be straight or pitched slightly down in front.
05-11-2015, 01:46 PM | #13 |
Rep 887
Drives: Enzo F23 228i
I also experienced this at first. I adjusted the seat all the way down and slowly brought the back up until I was comfortable, then adjusted the thigh extension out two clicks and set memory. This took me a couple of weeks, but I have since been uber comfortable in the seats, and I don't use the lumbar unless I'm on the hwy for a long cruise!
05-11-2015, 03:50 PM | #14 |
Rep 288
I sold my 2007 Z4 coupe (automatic) and bought a 2014 M235 (manual) because getting in and out of the Z4 wrecked my lower back (I'm almost 61 and have some lower spinal "issues"-sux getting old!). The seat was great, once I was seated, but the twisting and turning needed to enter/exit the vehicle was light torture.
Anyway, getting the M235 solved my problems. Both vehicles had/have the sport seats, and once I got the seat location adjusted properly, I haven't changed it since. So far, after 12 months, no lower back pain...at least, caused by the seats in the car... |
05-11-2015, 03:54 PM | #15 |
Rep 887
That is exactly why I didn't get a Porsche Boxster...daily use and the ingress and egress of the vehicle killed me, and I'm only 55! The 2 series really fit the bill!
05-11-2015, 04:17 PM | #16 |
Rep 721
Seats in the M235i are quite comfortable and don't cause me any pain by themselves which is good since I've had fusion/decompression surgery for L5-S1. How exactly is it hurting you?
05-11-2015, 11:27 PM | #17 |
Rep 4
I was in a VW with cloth seats previously so the current setup is very different. The M235i is certainly lower and has a much different seating position inside. I've tried as far as possible to keep the setup similar with regards to positioning to my back. Failing that I tried changing a few things.
05-11-2015, 11:30 PM | #18 | |
Rep 4
05-11-2015, 11:41 PM | #19 | |
Rep 4
There is relief from the pain when I'm standing straight, I would say it dissapears unless I'm sitting or lying down. I've tried now driving with a small pillow positioned just above my lumbar curve which seems to be helping a bit. Thanks everyone for the suggestions, I'll try them out today and see if it makes a difference |
05-12-2015, 12:22 AM | #20 |
Rep 855
This issue and auto dimming mirrors is the main reason I opted for the premium package even at the ridiculous premium price. Lumbar support is worth it!
05-12-2015, 10:54 AM | #21 |
Rep 7,047
I have both neck and lower back spine issues and that is why I MUST have full power seats, so I can do the small adjustments that can make a big difference in comfort.
For my back issues I do not use lumbar support at all, because when I do it causes more pain. I set lumbar to full off. I try to keep the back as straight as possible so that I am not pulling my head forward and causing neck strain. Thigh extension is full out to provide full support. The idea is to get as much body contact with the seat as possible so as to distribute your weight over as much of the seat as possible thus reducing any pressure points. Getting the seat where it's best for you could take a little while and a bit of adjusting, but over all these BMW sport seats are fantastic and very supportive when adjusted properly. I even use the memory settings for longer trips so that I can set a couple of different positions that I find comfy and the switch between the two to keep circulation good and alleviate pressure points. |
mrmike449.00 |
05-12-2015, 12:45 PM | #22 | |
Rep 721
