05-25-2016, 12:21 AM | #1 |
Rep 83
Powered subwoofers
Hi guys
Wondering if anyone has added a subwoofer (not changing the underseat)? The reason is that I listened to BxxSxxxd underseat replacement and still found the sound spectrum more in the mid-range rather than a solid bass. I am turning to powered subwoofers since they are cheap and almost PnP. And if I really need that space back (my trunk is 99.99% of the time empty though), they come off in just seconds. These two have generally good ratings: http://www.carid.com/jbl/12-gt-bass-...basspro12.html http://www.carid.com/infinity/10-bas...-basslink.html |
05-25-2016, 02:42 AM | #2 |
Rep 83
05-25-2016, 05:45 AM | #3 |
Rep 103
JL Audio has some powered Microsub+ and other models with shallow woofers and amp built in. You will pay a little more but they are pretty impressive.
I've thought about doing the XD600/6 amp and upgrading the 6 speakers inside(not the center channel) and adding one of them myself if upgraded underseat woofers don't do the job. |
05-25-2016, 01:22 PM | #5 | |
Rep 2,942
You'll still hear output since bass is generally omnidirectional and will travel through objects (walls, seats, etc.), but they will be significantly muffled and need to be balanced for the rest of the system -- and magnify the potential for any rattles in the rear of the car. And ... if the subs handle any sort of mid-bass above 250Hz or so, you'll barely hear that at all.
--Helmets are for closers.-- <<Current: "Blackened" '18 NBM Porsche 718 Cayman ... Gone (but not forgotten): "Blackened" MG '15 228i M Sport w/aFe filter/scoop, Hertz drivers, P3Cars multigauge, other goodies>> Last edited by Viffermike; 05-25-2016 at 01:29 PM.. |
05-25-2016, 10:43 PM | #6 |
Rep 556
05-25-2016, 11:12 PM | #7 | |
Rep 83
Hi Mdputnam
I just figured. But they cost way too much. $500 for just the enclosure. The subwoofer itself is $200 only. I guess that's the money one has to pay for custom-built, non-mass production products. Quote:
05-25-2016, 11:30 PM | #8 | |
Rep 83
Hi Viffermike
You are absolutely right about the discount from the insulation of the trunk. But I use to have a cheap no-brand self-powered underseat woofer (the power is low and the sound quality is not that great) and I put it in the trunk of the E82 135i, the bass spectrum was still improved significantly. Regarding the rattles, I didn't have any issues (not sure in the case of a true subwoofer). Right now, I turned up treble a little and bass a lot, and shifted to the rear a little to balance for this zero bass surround system. It sounded better for pop music but might not fit other genre. I also had a chance to listen to an Alpine retrofit system with BxxSxxxd woofers. The more I listen, the more I am convinced that swapping the HK tweeters, mids and woofers might not be the key. All that is missing is "bass". That's why I think adding a subwoofer is the logical move. I wouldn't mind to go for other options, particularly OEM-look upgrades, but at the moment they are disappointing. Quote:
05-26-2016, 09:53 AM | #9 | |
Rep 556
Well, if $165 is more inline with your budget for a custom enclosure, then check out this one. |
05-26-2016, 10:18 AM | #10 | |
Rep 2,942
I would seriously reconsider what you do first. You may find that an aftermarket amp(s) powering the entire system -- including those Bavsound Ghosts -- solves many of your bass response issues. You need to deliver clean power with minimal EQ first before you mess with upgrading the bass capabilities of a car.
05-26-2016, 10:31 AM | #11 |
Rep 887
Drives: Enzo F23 228i
Can anyone say Bazooka Tube....LOL
05-26-2016, 10:43 AM | #12 | |
Rep 83
Wow, that's amazing!!! I never thought it's a DIY task. To be honest, I actually think it demands more than a mechanic's hand.
Definitely a must-try!!! Quote:
05-26-2016, 11:01 AM | #13 | |
Rep 83
You can't be more correct. I saw your other post about the need of juice to power a bass driver. That single HK amp is definitely underpowered for this purpose, not to mention all other channels it's powering simultaneously.
I guess the problem is not as simple as swapping a driver or adding a boom box.... But the convenience of a boom box is just too tempting... very successful marketing those big brands... Quote:
05-26-2016, 11:07 AM | #14 |
Rep 83
05-26-2016, 10:45 PM | #15 | ||
Rep 1,753
