2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack 19" wheel fitment help needed! 35 profile rear?
      09-15-2019, 08:43 PM   #1
235Dude
Drives: 2016 M235i
Thinking to get some Apex wheels: 19x8.5 et35 front and 19x9.5 et43 rear. Would like to run 225/35/19 and 255/35/19 tires. I'm lowered on M Performance springs (only 10mm drop). I don't want to use spacers or touch camber. Will this setup work?
Not sure how much of a difference the 35 profile rear tire will make. Also would 235 fronts and 265 rears be out of the question?
2016 M235i | BSM | 6SPD | BMS JB4 | Dinan Intake | Wagner Evo 2 Comp IC | VRSF DP | ER CP | Dinan Exhaust | M Performance LSD | M Performance Springs
Gone: 2016 F30 340i, 2015 Corvette Z06, 2011 E92 335i, 2007 E92 335i, 2008 Corvette Z51, 1999 E46 323i, 2001 Boxster, 1999 Carrera 2, 1997 Corvette, 2001 Camaro SS
      09-23-2019, 01:28 AM   #2
235Dude
Drives: 2016 M235i
Bump
      09-25-2019, 08:56 AM   #3
Sonertial
Sweden
47
Drives: M240i 6MT
The stock staggered setup is 245/35R18. With 255/35R19 your diameter will be a fair bit (~32mm) higher. With 9.5" and ET43, you'd be pretty flush. That with your high profile makes rubbing quite a high risk. 265s lowered will push that towards definite.
Your speed will read low (by over 5%), which can be illegal.
30 profile rear would be a better fit. If you can get the tyre you want.
I have 265/30R19 ET40 9" rear, which is rather extreme. I would prefer a higher offset, say 45, (wasn't available in the wheel I wanted), but I do not rub. My car is not lowered.
Front you'll be fine I think. I am running 235/35R19 with an 8" ET45 rim, but I have done the LCA mod which pushes it out a fair bit.
      09-25-2019, 07:16 PM   #4
235Dude
Drives: 2016 M235i
Thank you sir. Going to just suck it up and get the right size for the rear 255/30/19. Any pics of your rear fitment? Et40 sounds pretty aggressive.
      09-26-2019, 01:42 AM   #5
Sonertial
Sweden
47
Drives: M240i 6MT
It is. I like the grip though, it gives me a dramatic improvement on my occasional track outings.
Some pics here from when I installed them:
https://www.2addicts.com/forums/show...8#post23526698
The front stance has changed a bit since I installed the control arms. The pic below is pretty current.
