2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum M240i Recall
      09-15-2019, 11:54 AM   #1
liebetrau88
Drives: 2017 M240i xDrive
M240i Recall
I just had my car at the dealer getting the oil changed and brake fluid flushed. They gave me a call and said there was a recall for a "glitch" in the system that would require reprogramming. They said the "glitch" would have the car throw a CEL. They told me it would take 5 hours to reprogram everything so I opted to not do it as I needed the car back.
I go to the BMW website to lookup what the recall is, and low and behold, there are no recalls for my car. My SA told me the recall number is "12 01 19". All of this seems a bit odd and not adding up.
Any of you ever had this same issue? I remember seeing something similar to this happening in Canada and then the car was sluggish/less responsive and the exhaust burbles were quite a bit less noticeable.
      09-15-2019, 12:21 PM   #2
babaikram
M6GCComp, Porsche Cayman S PDK, Peug 208 GT1 BPS
United Kingdom
512
Drives: .
It is going on in England as well. It is the DME unit being changed or reprogrammed. They have done this on my m240i and G30 5 series when they went for routine servicing. It is a silent recall
Acceleration is heavenly
      09-15-2019, 12:38 PM   #3
Sportstick
Sportstick's Avatar
4647
Drives: '15 228i and '24 X3 sDrive30i
It is important to distinguish between a “recall” which involves NHTSA, and a “service campaign” which is an action an OEM may undertake at will without notice.
      09-15-2019, 12:44 PM   #4
liebetrau88
Agreed, however, he used the exact wording of it being a recall. More than likely just using a generic term on his end.
      09-15-2019, 02:29 PM   #5
babaikram
United Kingdom
512
Drives: .
I got a letter to take the G30 from BMW to a dealer with a list of possible symptoms but after the EGR recall had been done as part of the servicing. The phrase 'EGR cooler recall' was used on the receipt.
My m240i is still with them for like a month now waiting for a part from Germany to replace the rear LED trafficator. So I don't have a receipt yet .
I am using a newer replacement m240i which I cannot wait to return.Its step auto gear (2TB option) is so slow to change unlike mine, the exhaust is so muted.
      09-15-2019, 02:52 PM   #6
MarkDemma
MarkDemma's Avatar
When I took mine in for a 9000? mile service (oil change, mainly) they said they needed to do the ECU update I believe you are talking about and that they wanted at least 5 hours to do it. He didn't use the word "recall" but said "they want us to make sure any car that comes in has it done". Didn't provide any details about what changes were in the update. I've heard some folks swear the exhaust was quieter after, I believe.
      09-16-2019, 01:51 AM   #7
keylime503
Drives: M2C 6MT, Audi A4 Avant
I had the same thing done last week. SA also referred to it as a "recall" that required DME software update. All my settings were reset after I got the car back. I had read about the exhaust being quieter after this update, but I honestly can't tell if the exhaust has changed or not since getting the car back.
      09-16-2019, 01:29 PM   #8
babaikram
United Kingdom
512
Drives: .
I hope my MPE would not be quieter when I have the car back. Otherwise there would be a riot
      09-16-2019, 08:35 PM   #9
EstorilM240
Drives: 2017 M240i 6MT
What's the recall and how do you check if your particular car or VIN is affected? I most recently did maintenance in August, nothing came up, and I don't plan to use the dealer now that the "free" 36K maintenance is over, so I want to know if there's something I should address before warranty ends at 50K
      09-17-2019, 10:20 AM   #10
USA-RET
USA-RET's Avatar
605
Drives: Estoril Blue M240i
I got one in my email yesterday from my dealer. The email provided a website to verify the recall. I could enter my VIN and see if my specific was affected. When I did, I received "No Recall on your vehicle".
On that website they provided an option to allow any recall info be sent via email based on the VIN I provided. I checked the box since this is my BMW dealership.
I would imagine anyone entering their VIN could see if a recall is pending
https://www.bmwoffortmyers.com/bmw-r...erv_2019-09-05
dradernh4337.00
      09-17-2019, 11:07 AM   #11
liebetrau88
They are probably pulling that from the BMW website. My car shows no recall in there. As a previous post said, it's probably a soft service campaign.
      09-17-2019, 11:40 AM   #12
aerobod
aerobod's Avatar
3605
I had the Canadian Recall “Campaign ECR-B0001-19-002 Program Control Units DME” done on Fri, the dealer had the car for about 3 hours from my drop off to pickup. No noticeable difference in performance or sound, as verified in this thread: https://f30.bimmerpost.com/forums/sh....php?t=1631041
My car showed no recall pending on the bmw.ca website (likely due to Transport Canada not mandating it yet).
The description in the recall letter was:
“Due to a software error within the ECM, the monitoring for the oxygen sensor heater is disabling itself after the pending fault code is set, so that in the following driving cycles the malfunction cannot be confirmed (no confirmed fault code is set) and the MIL will not illuminate, this issue could cause emissions to exceed the prescribed standards.”
On the back of the letter it indicates that your warranty may be invalidated if you don’t have the recall done.
      09-17-2019, 11:46 AM   #13
omera60
omera60's Avatar
Turkey
195
Drives: 218i Coupe
I go to the BMW website to look up what the recall is, and low and behold, there are no recalls for my car. My SA told me the recall number is "12 01 19". All of this seems a bit odd and not adding up.
Originally Posted by mecodoug View Post
Is it possible that this is only for cars with an automatic transmission? I hate to get a re-flash because I set up several customized settings (like the digital speedometer and an accurate speedometer reading), and my Carly subscription has lapsed.
Can you please provide me with your VIN's so I can check from BMW's internal system.
      09-17-2019, 11:46 AM   #14
mecodoug
Drives: 2017 M240i 6-speed
Is it possible that this is only for cars with the automatic transmission? I hate to get a re-flash because I set up several customized settings (like digital speedometer and an accurate speedometer reading), and my Carly subscription has lapsed.
      09-17-2019, 11:55 AM   #15
MarkDemma
MarkDemma's Avatar
Mine is a manual and they did it. Had to reprogram everything!
      09-17-2019, 12:09 PM   #16
aerobod
aerobod's Avatar
3605
My car has a manual transmission. In Canada the recall seems to apply to all 2-series with the B48 and B58 engine up to the 2020 model year. Specifically in the recall letter it states:
“BMW has determined that certain BMW 2 Series, 3 Series and 7 Series Model Year 2016-2020, BMW 4 Series Model Year 2017-2020, BMW 5 Series Model Year 2017-2019, BMW X2, BMW X4 and BMW X7 Model Year 2019, BMW X3 Model Year 2018-2019 and BMW Z4 Model Year 2019-2020 vehicles may not fully meet the Federal requirements for Emission.”
      09-18-2019, 11:58 AM   #17
keylime503
I just looked at my work order from my service visit last week when they did this mysterious recall. Here is what it says:
PERFORMED NECESSARY RECALL PER BMW B120119 Service Action: Program the Digital Motor Electronics (DME): B12 01 19 10012880400
Search this Thread:
