2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack Xdrive wheel recommendations
      01-13-2017, 11:12 PM   #1
Jmo550
Drives: 15' X5
Looking for recommendationson staggered setup
Hate the 225 tire look
I'm sure plenty of members here have done some setup
Thinking of a spring drop too
Maybe spacers
2015 BLK/BLK X5 35i - M sport
997.1 GT3
      01-17-2017, 04:48 PM   #2
Transfer
Transfer's Avatar
5254
Drives: Bronco Wildtrak, Tesla MYP
My thoughts are to find wheels that fit tires 225 front and 255 rear. Xdrive feels great with the exactly equal diameters and wider stagger. For a summer set I would personally go with 19s and for winter 18s. Try to avoid spacers.
Front 8-8.5", offset 40-35
Rear 9-9.5", offset 50-45
VMR wheels have great fitment as do many others.
      01-30-2017, 11:32 PM   #3
SerenVoX
SerenVoX's Avatar
No_Country
146
Drives: M235i Xdrive
Do you know what the offset is for VMR V705? I hear 225/40/18 on either the 18x8 or 18x8.5 and then the 255/35/18 on the 18x9.5 will be a good setup. What offsets and and which front wheel size would you recommend if I do 18x9.5 rear?
      01-31-2017, 11:05 AM   #4
Luminous
Luminous's Avatar
743
Drives: 2019 M5 Competition
Maybe spacers
I got the HRE FF15s in a 19" staggered and love them! Tires are 235/35 and 245/35. With xdrive it's crucial to make sure the rolling diameters of front and rear are as close as possible, ideally under 2% difference.
2019 SG M5C
2015 SO M3 6MT
2015 BSM M235xi
      02-01-2017, 04:23 PM   #5
Transfer
Transfer's Avatar
5254
I think there are two offset options for both front and rear, one being more OEM like and the other pushed farther out. Check with VMR.
SerenVoX146.00
      03-12-2017, 10:25 PM   #6
SerenVoX
SerenVoX's Avatar
No_Country
146
I ordered some wheels, 18x8.5 et42 front and 18x9.5 et45 rear.
Keep In mind I have Xdrive so Ive been told its important to keep rolling diameter below 2% between front and rear. With that being said it's been from research that I'll have no issues running 225/40/18 front and 255/35/18 rear.
Can anyone say if I can run bigger tires while staying below the 2% needed on staggered setup for xdrive? For example is 235/40/18 front ok with 255/35/18? Would it beneficial to just go with the 225/40 vs 235/40 front? Can I go bigger than 255 rear?
End goal is I want to run biggest/thickest tires with no rub on the wheel specs mentioned while not causing issue to xdrive.
Any feed back is appreciated.
      03-13-2017, 07:01 AM   #7
x233
Ukraine
284
Drives: M2C, M235xi
I ran 235/40/18 front and 255/35/18 for a while but returned to 225/40/18 because a) it always felt like the car struggled a bit to get going (compared to 225/40) and b) it didn't handle as well as with 225/40. On the positive side the brakes were better. I would avoid the 235/40/18 + 255/35/18 combo. Also, I am not sure it will fit with your front ET42 and 8.5 wide wheel.
      03-13-2017, 04:22 PM   #8
SerenVoX
SerenVoX's Avatar
No_Country
146
Thanks for the feed back, sounds to me I'll be good with the 225/40 front. Any recommendations on the rear? Can I run 255/40 vs 255/35 and still be under the 2% and no rub?
      09-12-2019, 09:42 PM   #9
OldCrow7xx
Drives: 2016 M235i Xdrive 8A
I never considered my x drive complicating things. I did months of research to find a rim, width, offset, and tire that would fit the rear in my price range (nothing Im a peasant driving rich mans cars).
So I ended up with 225/40 on 8s in the front and 255/35 on 9s in the rear. It looks mean and nasty I love it- but should I be worried about it messing with my traction control system and x drive system?
Thanks in advance!
2016 F22 M235 8A HK NBTevo | CTS HEX Intake | CTS Chargepipe | Gplus Intercooler | VRSF DP | BM3 Stage 2+ | 18" CSL Replicas | XHP X-Delete
      09-13-2019, 01:28 PM   #10
marcthedark
Drives: M240i xdrive Convertible
Why? 225/40 and 255/35 have an almost identical rolling radius so your xdrive is fine (happier than with the stock 225/40 and 345/35 stagger) and the traction control steps in if there is slip so fitting different tires makes no difference for the car (as slip depends on tire width/ tire itself/ temperature/ conditions.... there is more/less depending on many parameters anyway)
