07-31-2019, 07:10 AM | #1 |
Rep 439
Drives: 2016 M235i Xdrive 8A
Help with moving the 19s
Greetings- I am looking at a set of wheels on eBay and this would be my first time going for 19s on a car.
They are staggered and the back pair is 19x9.5 with offset value of 35. My reading and guessing says this could be a bit aggressive to still go et35 on a 9.5 inch rim??? What size tire would this need, and will this fit on the m235 without any suspension modification? Thanks !!
2016 F22 M235 8A HK NBTevo | CTS HEX Intake | CTS Chargepipe | Gplus Intercooler | VRSF DP | BM3 Stage 2+ | 18" CSL Replicas | XHP X-Delete |
08-04-2019, 10:45 AM | #3 |
Rep 2,872
This may help: http://www.tire-size-calculator.info/ Buying wheels on eBay is a real crap-shoot, even if you can verify size, backspacing, and center bore size; still the question of whether they are selling b/c one is bent.
08-04-2019, 11:23 AM | #4 |
Rep 1,303
Drives: 2021 C8 Corvette 1LT
19x9.5et35 will have about 15-20mm of poke. I was running 19x9.5et44 and had some decent poke (I measured roughly 8-10mm) on stock suspension with 265/30 tires. Stuck out past the fender a tad, but nothing noticeable unless you were looking for it.
08-04-2019, 11:13 PM | #5 | |
Rep 439
thx
08-05-2019, 12:03 AM | #6 |
Rep 1,303
I liked it. The 19s were the OEMConcepts 437m replicas. 19x8.5et39 front 19x9.5et44 rear. 235/35/19, 265/30/19 with stock suspension. Zero rubbing.
Personally, I got better performance from the 18s though and they were close in fitments. VMR wheels 18x8.5et42 front 18x9.5et45 rear. 235/40/18, 265/35/18 with stock suspension. Zero rubbing. With both setups, the VMR being slightly closer inwards from the higher offsets, still had slight poke in the back. The fronts were damn near flush.
Project Car: DF Goblin
-Built LSJ-T 2021 C8 Corvette 1LT 2021 Model Y Performance |
VMRWheels2038.00 |
08-05-2019, 12:24 AM | #7 |
Rep 1,303
These are the 437m replica 19s for size comparison
08-05-2019, 08:39 PM | #8 | |
Rep 439
08-06-2019, 04:05 PM | #9 | |
Rep 439
Do I need to worry about that at all?
08-06-2019, 04:36 PM | #10 | |
Rep 1,303
If the wheel has a lip to it, usually a negative offset is required to pull the spokes of the wheel away from the hub (think concave wheels). If the wheel has no lip to it, you can get away with most any offset so long as it's not more than the wheel itself (8.5in wheel = 215.9mm, offset of 0 would put the hub centered on the wheel, or 107.95mm from the face of the wheel). For an 8.5" wheel, an offset of 107mm would put the brakes against the face of the wheel causing contact. For the 2er, a 9.5" wheel can fit on the back axle with a high offset (50-55mm, may need a spacer though to clear the strut on the inside). On the front, 8.5" wheel is about the widest you can fit on stock suspension and would need an offset between 35-42mm. The picture below shows wheels that have a "lip" on them. This car has them on the front and back, but notice that the front wheel has a smaller lip, most likely due to a thinner wheel and to accommodate clearance for the front brakes. |
08-06-2019, 04:41 PM | #11 | |
Rep 439
I basically want 19s with a really deep shiny lip. Thats what I am trying to achieve. Staggered 19s with a deep shiny lip that dont rub or scrape anything. Thanks
08-06-2019, 04:56 PM | #12 |
Rep 1,303
Yea the 2er doesn't have space front or rear to have wide wheels AND a lip. You'd have to use a smaller wheel width, like 7.5-8" to get a wheel with a deep lip/concave without having to modify the body or suspension. 9.5et35 would poke quite a lot past the fender so would have the potential to rub over large bumps and hard cornering.
OldCrow7xx72.50 |
08-06-2019, 04:58 PM | #13 | |
Rep 439
08-06-2019, 05:36 PM | #14 | |
Rep 439
http://vi.vipr.ebaydesc.com/ws/eBayI...rsion=eefc707b
08-06-2019, 06:10 PM | #15 | ||
Rep 1,303
08-06-2019, 06:12 PM | #16 | ||
Rep 1,303
08-06-2019, 09:12 PM | #17 | |||
Rep 439
I think i will still need to buy new tires because they look too narrow on the stock 7.5/8 inch rims now. It looks very tacky haha rim sticks out past the rubber.
08-06-2019, 09:27 PM | #18 | |
Rep 3,494
It's not at all difficult to end up with wheels and/or tires that won't fit on your car, no matter which car it is. Ask me how I know this.
08-06-2019, 10:36 PM | #19 | |
Rep 439
The fitment.com website is pretty killer too where you can see setups on your model car.
08-08-2019, 06:17 PM | #20 | |||
Rep 439
If 18x8.5 et35 is ok 19x8.5 et35 should be ok too right? As long as I step down from a 40 aspect ration to a 35 or 30.... https://rover.ebay.com/rover/0/0/0?m...2F273777168963
08-08-2019, 07:57 PM | #21 | |
Rep 1,303
OldCrow7xx72.50 |
