06-05-2015, 03:41 PM | #67 | |
What goes here?
454
Rep 1,356
Drives: 2019 G30 M550i
Garage List 2019 BMW M550i [0.00]
2021 BMW M3 Competi ... [0.00] 2019 BMW M5 Competi ... [0.00] 2016 BMW M3 [0.00] 2014 BMW M235i [0.00] |
Any stocking distributor in the US yet that can sell? Turner!?
2019 G30 M550i
GBNF: 2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i |
06-07-2015, 06:14 PM | #68 |
Rep 356
Both front and rear subframes need to be removed, or lowered, to install and/or remove sway bars. The new design used by BMW (not just in the F2x chassis) is nothing like other models and requires a little more work to get the bars in and out.
06-08-2015, 02:48 AM | #69 |
Rep 1,252
indeed same with F3x took like a full day+ at the shop.
Docrace 6266
06-08-2015, 07:52 PM | #70 |
Rep 356
We (Turner) have the rear bar listed. The front bar will be listed shortly. We are selling the front bar for $399 and the rear for $319.
06-08-2015, 08:03 PM | #71 |
Rep 986
Just an FYI ground-control is releasing adjustable sway bar links and camber plates for the F22 towards the end of the month. They said to watch for the announcement on facebook by liking their page
https://www.facebook.com/GroundControl |
06-08-2015, 08:46 PM | #72 |
Rep 957
Yeah not for the backyard mechanic. Unless you have a lift, and a way to support the engine while dropping the front sub frame and all the other bits in the way, well forget it. Mine took 8 hours on the front, 3 rear, but we did some other stuff while in there, inter cooler charge pipes ext.
06-09-2015, 03:48 AM | #73 |
Rep 211
The H&R anti-roll bar is available on the USA website but not on the official German website yet. I wonder why...
BTW, the front roll bar is adjustable with 2 holes. Which setting are you guys planning on? Stiff or less stiff? Will it make a big difference on the road? Thanks. |
06-09-2015, 08:01 PM | #74 | |
Rep 24
Or maybe should just wait about 1-2 weeks more? |
06-09-2015, 09:10 PM | #75 | |
Rep 356
My bars just came in today. I'll try to get some photos of them tomorrow. I think they will be installed Friday, so I'll try and get photos of that as well....if I can make it happen. |
06-12-2015, 09:47 PM | #76 |
Rep 356
Sway bars are installed. My first impression, wow! The car is MUCH flatter in corners (ie: on/off ramps). I have an event on the 27th, so I'm interested to see what the "limit" is with these new bars. But, so far they are awesome!
As far as install goes....it's tedious. Like mentioned before, you have to lower both the front and rear subframes. Plan on a professional shop charging 6-8hrs. If you have access to a lift and are mechanically inclined, plan on a very good portion of your day. If you plan on doing this in your driveway, DON'T. I'll report back after my next event. PS - both bars are now listed on the Turner Motorsport site. |
06-14-2015, 10:02 PM | #77 | |
Rep 211
BTW, which stiffness setting did you choose for the front sway bar? Any big difference between the 2 settings? |
06-15-2015, 08:17 AM | #78 | |
Rep 356
I'll try and get some photos up shortly of the bars. |
06-15-2015, 08:07 PM | #82 |
Rep 356
06-15-2015, 08:07 PM | #83 |
Rep 356
06-15-2015, 08:19 PM | #84 |
Rep 211
Awesome. Let us know the difference between the 2 setting!
06-15-2015, 09:12 PM | #85 | |
Rep 957
I have the same setup, the joints on the bar will start to fail after a track day or two, or some spirited driving. Also you won't notice it unless the car is loaded a certain way, but there is some interference. Get it on a rack in a few weeks and you will see where it rubbed. I am using the stiffer setting. I have the Kmak camber plates, and the m3 Lca so it may not be as dramatic on just the springs. |
06-16-2015, 08:14 PM | #88 | |
Rep 356
What adjustable links are you using? |
