2Addicts | BMW 2-Series forum Technical Topics Cosmetic and Lighting Modifications LED Fog Light Bulbs
      08-27-2018, 01:48 AM   #1
redcars
Drives: 228xi
LED Fog Light Bulbs
Can anyone recommend LED bulbs to replace my halogen fog lights? I want some more fill when they come on as cornering lights, and would like them to still be functional as fogs when I do turn them on. Thanks.
      11-28-2018, 02:11 PM   #2
BimmerDoctor
Colombia
24
Drives: 2024 M240i
did you ever find something?
      02-25-2019, 01:39 PM   #3
bmw_fascinated
bmw_fascinated's Avatar
15
Drives: F22 228i
It might be difficult to find a bulb that does this without other side effects.
Since the reflector is designed for a point or filament light source, everything that is bigger should spread the light more. However you might end up glaring others and yourself if fog is present.
I use these for just a bit more light output (have my fogs coded on with low beam) https://www.ebay.com/itm/153279655150
I am curious about those: https://www.ebay.com/itm/352513148972
These might be overkill for fog lights:
https://www.ebay.com/itm/263984611614
These might spread/diffuse the pattern but with the reflector geometry the fog lights will never be a real cornering light:
https://www.ebay.com/itm/173663074236
