12-15-2022, 04:16 PM | #1 |
Rep 344
Car died driving down road shortly after cold start
So my m235 died last night about a mile down the road, had rough cold start (battery was low) check engine light came on driving down road then it started making a screeching noise (sounded exactly like a rock stuck between caliper and dust guard), then the car sputtered and died, honestly thought the engine blew due to the terrible noise and complete loss of power (maybe an overreaction). Was gonna get it towed but ZERO tow company's were available. So I said f it and put my jump starter on the car and turned it on, miraculously it ran totally normal and I got it back to the house, still has the check engine light on and these are the codes I got. Any help or idea what could've happened would be greatly appreciated.
12-15-2022, 04:19 PM | #2 | |
Rep 344
12-15-2022, 04:34 PM | #3 |
3699
Rep 3,618
If the battery was causing low voltage messages before the codes were set, I would erase the codes, charge the battery fully and see if they come back, before doing anything else. The voltage drop on a cold start with a low battery could cause all sorts of other temporary issues relating to electrical systems and sensors.
12-18-2022, 08:08 AM | #4 | |
Rep 344
aerobod3698.50 |
12-18-2022, 01:35 PM | #5 |
Rep 1,019
I don't drive a lot, and when I do they are mostly short trips. As a result my battery never fully charges, in fact it slowly discharges over time, till the car starts to complain "abnormal battery discharge" or something like that. Or at least that was what used to happen several BMWs ago. Now I just make a point of putting the trickle charger (I use a CTEK) on the car every week or so. Have never had any problems since.
F22leo245.00 |
12-22-2022, 07:20 AM | #6 | |
Rep 1,146
I had pretty much the same, except the screeching noise.
The car was jumping like it was having an orgasm then died, left it a bit and then it started The battery was screwed, the dashcam had killed it. For a few weeks while I was troubleshooting it, it would start like that and only run properly after a jump start If it's an AGM battery it's probably damaged , get it checked out but yes battery problem for sure You'll get what I call BULLSHIT codes due to the battery, I had all kinds of codes new battery is probably required depending on the age if battery is equal or older than 5 years replace Quote:
F22leo245.00 |
12-25-2022, 02:14 PM | #7 | ||
Rep 344
