01-21-2023, 06:41 PM | #222 |
Leave the gun. Take the Canoli.
9052
Rep 7,621
Did you switch the picture algorithm back? Uploads now via the app are back to poor quality. Here's the app vs website upload.
Current: 2023 Santorini Blue ///M8 ||| 2023 X3 M40
Retired: 2021 Enzian Blue ///M4 ||| 2018 ///M4 ||| 2017 ///M4 ||| 2014 435i ||| 2009 335i Coupe ||| 2007 335i Coupe |
01-21-2023, 07:54 PM | #223 | |
Private2
2999
Rep 49
Drives: BMW M3 F32 Coupe!
No change on the algorithm. Let me look into this now, Can you remind me, are you on iOS or android?
Test 23456rt
snareman9051.50 |
01-21-2023, 07:55 PM | #224 |
9052
Rep 7,621
Android. Thanks
apptest2999.00 |
01-21-2023, 08:03 PM | #225 |
Private2
2999
Rep 49
Any info you can give me about the original image on your phone? Like the format (JPG, HEIC) or size?
Test 23456rt
01-21-2023, 08:05 PM | #226 |
9052
Rep 7,621
Here you go
apptest2999.00 |
01-21-2023, 09:21 PM | #227 |
Private2
2999
Rep 49
Ok I just put a new release in the Play Store. It’s still called 5.5.4, but it is available now, try checking the play store to see if it lets you do an update. If not, it might take another hour to get to your local store, see if that version gives you as better image quality?
For sure the image quality was not great on the latest version, so I tweaked it and I saw an improvement on my test images
Test 23456rt
snareman9051.50 |
01-21-2023, 09:30 PM | #228 |
9052
Rep 7,621
Updated app...
(Edit: seems improved)
apptest2999.00 |
01-23-2023, 08:12 AM | #229 |
Rep 3,995
5.5.4 working great! 🙏
Current: G82 M4 Comp xDrive // Frozen Deep Grey
Current: 95B.1 Macan Turbo // Dark Blue Metallic |
02-03-2023, 10:22 AM | #230 |
Field Marshal
6729
Rep 1,829
Drives: '08 E92 M3
I found an issue (glitch) while using the App on my iPhone 8 (yeah I know it's old).. I'm including some screen shots to try and explain what happens.
Issue: When trying to type a post the screen area dedicated to text is limited by the App text formatting header and the iPhone keyboard. If one tries to write more text than can fit into the text write field then one gets locked into the writing field because one can not scroll down 'below or behind the keyboard. The scrolling function needs more than the space available or the cursor simply bounces back up above the keyboard. In other words, the scrolling feature only works above the keyboard and below the text header i.e. it isn't possible to see any text that has been written 'behind or below' the iPhone keyboard field. See images below. .
'08 E92 M3 DCT Melbourne Red/Bamboo Beige Leather/EDC/SSP Spec-R DCT clutch discs/SSP Pro-Gold DCT Fluid/Quaife LSD/3:45 Final Drive by Diffs Online/BE Bearings & ARP Bolts/Vibra Technics Engine Mounts/M3 World HFC X-Pipe/LUX H8 180/BPM Sport DCT Tune/PFC Z-Rated Pads/ECS Brass Brake Caliper Bushings/Alex Shop Solid Sub-frame Bushings/Motul 600/Tint
///M Power-Belgium63410.50 apptest2999.00 |
02-03-2023, 09:09 PM | #231 | |
Private2
2999
Rep 49
Test 23456rt
DrFerry6728.50 |
02-04-2023, 10:39 AM | #232 |
Rep 484
Drives: 2018 M2 6MT
apptest Here’s a strange one for ya. The iOS BIMMERPOST app shows a very long gray area below the post linked below. I’ve scrolled for a very looooong time and never found the end of the gray region. I think it was scrolling the whole time though, because it took just as long to scroll back up out of the gray region to the post.
https://www.bimmerpost.com/forums/sh...php?p=28903473 |
apptest2999.00 |
02-04-2023, 10:48 AM | #233 | |
Private2
2999
Rep 49
Test 23456rt
jefe2000740.50 |
02-04-2023, 04:25 PM | #234 | |
Private2
2999
Rep 49
Test 23456rt
jefe2000740.50 |
02-04-2023, 04:28 PM | #235 | |
Private2
2999
Rep 49
I’m using it on an iPhone 8 right now and I can scroll this editor screen freely, meaning when the keyboard is covering my reply text, I can just scroll/swipe it up so that I can see the bottom of what I typed. Are you able to swipe it the text up so you can see the part of the text that is covered by a keyboard? ANd also want to confirm you are using 5.5.4, there was a much earlier version where scrolling was a problem, I think 5.2 or 5.3
Test 23456rt
02-04-2023, 04:37 PM | #236 | |
Rep 5,380
Drives: 2022 Aventurin/SS G82 xDrive
02-04-2023, 04:47 PM | #237 |
Private2
2999
Rep 49
You mean the endless grey area or not being able to scroll the post editor? (Endless grey area issue is confirmed bug and fixed)
Test 23456rt
'Cane8517.50 |
02-04-2023, 07:43 PM | #239 |
Field Marshal
6729
Rep 1,829
Drives: '08 E92 M3
apptest Ironically I tried replying to your post with your questions above being quoted, but the amount of text was too large a paragraph and I got trapped in the reply field and unable to scroll below the last few lines of your and mine quoted text. The text field header and text field reply block bump into the top of the screen if trying to scroll up and the field bumps into the keyboard when trying to scroll down. Like now I’m wwriting blind and can’t see what I’m typing.
///M Power-Belgium63410.50 M5Rick60142.00 |
02-04-2023, 07:45 PM | #240 | |
Private2
2999
Rep 49
Test 23456rt
DrFerry6728.50 |
02-04-2023, 07:46 PM | #241 |
Field Marshal
6729
Rep 1,829
Drives: '08 E92 M3
apptest Okay 👍🏻
02-04-2023, 07:57 PM | #242 | |
Field Marshal
6729
Rep 1,829
Drives: '08 E92 M3
Okay, I just updated to the latest version and am quoting your and my text above. The cursor now appears in the correct spot. I’ll copy and paste this text and see if I get locked into the field and unable to scroll. Okay, I just updated to the latest version and am quoting your and my text above. The cursor now appears in the correct spot. I’ll copy and paste this text and see if I get locked into the field and unable to scroll. Okay, I just updated to the latest version and am quoting your and my text above. The cursor now appears in the correct spot. I’ll copy and paste this text and see if I get locked into the field and unable to scroll. Okay, I just updated to the latest version and am quoting your and my text above. The cursor now appears in the correct spot. I’ll copy and paste this text and see if I get locked into the field and unable to scroll. Oh look 👀 it’s working now. Nice and fast easy scrolling now. Well done. I still think the text formatting header is too large though. Do we really need the large “post a reply” label font and blue circle button? Those two alone take up 20% of the screen space not including the keyboard. . . . . . .
