05-29-2020, 06:40 PM | #1 |
Rep 175
Alarm issues on F23
Hi guys,
Its the 2nd time this happens that I am sitting outside and all of a sudden my cars alarm system goes off. Both times I though someone touched my key but found it just laying inside on a table. There was no one near the car or no one touched it. It seems to happen on rainy days. Let me know if anyone else has this issue or if you know what can cause it. Thanks |
05-29-2020, 06:59 PM | #2 |
Rep 744
I had the same issue on my Honda Odyssey (not my BMW though). It turned out to be a door seal. We never noticed any water inside, but apparently it leaked just enough to trip the alarm.
05-29-2020, 07:11 PM | #3 |
Rep 8,942
I had a similar issue - they had to replace some sensor I think in the engine bay. I'll try and remember to dig through my records. It was very annoying for a few weeks, then a nightmare for the dealer since I had replaced my amp and they needed the stock one to flash the new sensor into the system.
05-29-2020, 07:18 PM | #4 | |
Rep 175
05-29-2020, 07:37 PM | #5 |
388
Rep 889
there have been reports of interior sensors doing it as well. in my case, i'm sure i was hip-dialing the fob button. i glued it inoperable and had no more trouble.
05-30-2020, 08:53 AM | #6 | |
Rep 175
I suspect the rain going in as culprit. Now to find from where... |
05-30-2020, 10:44 AM | #7 |
Rep 175
Guys just had more incidents now. There is no rain and my cars alarm went off this morning 4 times.
I am so shy from my neighbours now. For now i am keeping my car unlocked. Is there a way to lock the car without engaging the alarm. I really need help until i bring it to the dealer! |
05-30-2020, 11:12 AM | #8 | |
3615
Rep 3,585
If that isn't enough, use the key in the remote to manually lock the door, without using the remote itself. |
05-30-2020, 11:13 AM | #9 | ||
Rep 175
05-30-2020, 11:33 AM | #11 |
Rep 175
Yes it did work! Im not sure if you saw but i had posted another post regarding window issues that i am. When i use the big button for the 4 windows to come up after the operation of the convertible top randomly a window goes back up or down. I am thinking that something seems to happen when i lock the car with the window that is sounding the alarm. Not idea what it could be. I tried the reset of the window but did not work.
05-30-2020, 11:59 AM | #12 | |
Rep 1,268
And what year is this car? |
05-30-2020, 12:08 PM | #13 | ||
Rep 175
05-30-2020, 12:26 PM | #14 | |||
Rep 1,268
You definitely have either a sensor issue or convertible top control unit is going bad. In the F23, and I learnt this while flirting around with the Smart Top module, the convertible top unit (I may not be using the right terminology but it is the unit placed behind the rear passenger armrest panel) governs quite a number of things, including windows, side-view mirrors etc. My first smart top installation was, unfortunately, problematic. The unit wasn't seated correctly (as it runs in series with the top control unit) and I started noticing some odd behavior with alarms, windows and side view mirrors. Alarm went off on its own once, right after the installation. I was curious, and actually wanted to uninstall the smarttop unit, since nothing like that had happened before the installation, so opened the panel up to uninstall. Lo and behold, I hadn't seated the unit properly! Fixed that, and it has been close to two months with perfect operation every time. Anyway, take it to the dealer. I doubt it is the sensor operation since your windows are acting wonky as well, and the randomness of that tells me that there might be a "something on its ways out" problem, and if it's the top unit, you definitely don't want it failing with the top down Edit: I realize my story is anecdotal, and absolutely not technical, but there are some parallels with your issues, so I thought it is worth mentioning, since the top control unit is responsible for so much regarding the windows, and in my case, the alarm going off as well. |
Mtl128_2526.00 |
05-30-2020, 12:57 PM | #15 | ||||
Rep 175
05-30-2020, 01:12 PM | #16 | |||||
Rep 1,268
06-06-2020, 11:37 AM | #17 | ||||||
Rep 175
06-06-2020, 03:45 PM | #18 |
3615
Rep 3,585
My first impression of all the module errors is a low battery voltage either due to lack of use of the car or a failing battery. This is assuming there has been no aftermarket decive added to the vehicle that is plugged into any of the communication buses, such as the CAN bus.
