05-27-2020, 09:36 AM | #1 |
Rep 10
Spark plugs for stage 2
Ever since I got the car I haven't changed the spark plugs. and it has been about 33000 miles. Is it okay to go with 2 steps colder spark plugs for Stage 2 or should I go with 1 step colder and what gap size?
Also, is it possible for flames to shoot with new spark plugs? BM3 stage 2 (agg)/ Bms intake/ Vrsf catless Dp Last edited by thevinman01; 05-27-2020 at 01:11 PM.. Reason: added question |
05-28-2020, 08:40 AM | #2 |
Rep 87
Not sure about flames, or which plug to use. But I wouldn't flash Stage 2 without a new FMIC and Charge Pipe added to your mod list first. Charge Pipe the most crucial.
Chris |
thevinman011.00 |
05-28-2020, 11:09 AM | #3 | |
Rep 52
To your original question, they have recommendations on BM3's site: https://bootmod3.atlassian.net/wiki/...+and+which+gap I used the NGK SILZKBR8D8S (97506) gapped at .022 Last edited by Tomskeed; 05-28-2020 at 11:14 AM.. Reason: Including link |
thevinman011.00 |
05-29-2020, 06:49 AM | #4 | ||
Rep 439
Drives: 2016 M235i Xdrive 8A
2016 F22 M235 8A HK NBTevo | CTS HEX Intake | CTS Chargepipe | Gplus Intercooler | VRSF DP | BM3 Stage 2+ | 18" CSL Replicas | XHP X-Delete |
thevinman011.00 |
05-29-2020, 11:21 AM | #5 | |
Rep 52
"Colder" plugs reference the spark plugs ability to dissipate heat and keep the temps down in the cylinder, preventing knock, pre-detonation, spark plug tips melting, etc. Most recommendations are one step colder plugs for every 75-100 horsepower you add over stock, or if you're changing the air/fuel ratio up for some reason.
2016 M235i 6MT | VRSF Intercooler | Active Autowerke CP | VRSF Catless DP | M Performance Muffler | BM3 Tuned | 18" Alzor 030 Wheels | 8.8" Display & Apple CarPlay retrofit
OldCrow7xx72.50 thevinman011.00 |
05-29-2020, 11:46 AM | #6 | ||
Rep 439
thevinman011.00 |
Tags |
spark plug |
