2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack Dinan springs + 245/40R17 work?
      11-09-2017, 05:50 PM   #1
TakoMako
Drives: M240i Xdrive
No where in the forum seems to answer this question.
Would 245/40R17 fit without rubbing after installing dinan springs (drop)?
Any 17" wheels to recommend? (Preferably no spacer)
      11-09-2017, 07:42 PM   #2
SteveInfante
NewFinishColumbia/detailer
SteveInfante's Avatar
Drives: 2015 F31 xDrive
No idea about the drop but Apex ARC-7's in 17x8.5 in +40 are as close as you can get to perfect in a 17" wheel.
78' Honda CB400A project
      11-09-2017, 07:55 PM   #3
TakoMako
I assume you mean arc-8. Do you run them?
I am interested in the TR motorsport C2. Anyone care to share some thoughts?
      11-09-2017, 08:26 PM   #4
bryan_G01
bryan_G01's Avatar
1165
Drives: like i stole it...
you wont rub on 17x40.
It all depends on what tires since all mfg are different. Can say 245 on the side, but really be a 255, or 235 etc...
www.nybmwcca.org
Current Cars:
      11-09-2017, 08:32 PM   #5
TakoMako
So I just have to make sure that the tires are not overly wide.
Saw people running Hankook rs4 17" in the forum. I assume they will work with dinan springs according to your input. (No camber)
      11-10-2017, 11:24 AM   #6
bryan_G01
bryan_G01's Avatar
1165
the rear will give you the most trouble, and you can always dial in close to -2 in the rear without suspension mods.
www.nybmwcca.org
Current Cars:
      11-10-2017, 03:23 PM   #7
TakoMako
I guess the drop wouldn't be a good idea without camber plates.
      11-10-2017, 08:48 PM   #8
SteveInfante
I don't run them but I've seen enough of these threads to know lots of folks are running the TR wheels in 17x8 in +42. So a 17x8.5 +40 should be just about perfect. That's what I'm going to run. In the ARC-8.
      11-12-2017, 01:45 PM   #9
TakoMako
Forgot to ask, even for xdrive? 5/8" drop rear
      11-12-2017, 09:47 PM   #10
bryan_G01
bryan_G01's Avatar
1165
you don't need camber plates for the rear.
You can have a suspension shop dial in negative camber with factory setup.
www.nybmwcca.org
Current Cars:
      11-13-2017, 12:27 AM   #11
TakoMako
So what you are saying is, 245/40R17 (with rs4 or RE71R) will work in front with a drop, but the rear might need some negative camber. correct?
      11-13-2017, 09:08 AM   #12
bryan_G01
bryan_G01's Avatar
1165
no idea. both tires you mention are wider tires. going to be closer to a 250/255. Going that wide you def need camber. Why don't you call tire rack or discount tire.
www.nybmwcca.org
Current Cars:
      11-13-2017, 09:44 AM   #13
TakoMako
Will give that a try. We already know that the setup will work without a drop.
Hankook Ventus RS4 Review http://www.2addicts.com/forums/showthread.php?t=1421130
      11-23-2017, 12:50 PM   #14
john16443
Drives: 2017 M240i
I put this exact set up on my M240i with H&R springs and don't have a rubbing or interference issue. No camber adjustments have been made (yet!). I believe the H&R springs have a lower inherent ride height than the Dinan springs.
This will be my track set up, and I'll see how it works out on December 11th at Thunderhill.
      11-24-2017, 12:33 AM   #15
TakoMako
Nice, keep us updated. Any fender mod?
      11-24-2017, 01:28 PM   #16
john16443
Drives: 2017 M240i
No fender mod, and I don't think I'll need one either. With the smaller 17" wheels, I should have enough room in the wells in front. I know I have enough clearance in the rear.
      11-30-2017, 05:04 PM   #17
GrandMasterKhan
GrandMasterKhan's Avatar
Drives: Evo9, '22 X3Mc, Turbo S2000
Location: BMW Southpoint, Durham NC. Dinan/Carbahn authorized Dealer.
I am running 245/35/18 Mich Pilot Sport 3 summer tire, front and rear on TR motorsports C4 18x8 +45 no rubbing. Lowered on Dinan Springs M240i RWD.
It handles fantastically. I really like the extra front end grip.
      12-17-2017, 08:52 PM   #18
TakoMako
Any pics?
      05-16-2020, 04:54 PM   #19
GrandMasterKhan
Any pics?
I’m a little late to the party lol. My bad, but here are the pics.
      05-18-2020, 12:19 AM   #20
Solid67
Drives: 2019 M240i xDrive MP Edition
Very nice setup man! Do you think 255/35/18 would work on a 18x8.5 ET38 wheel and lowering springs?
2019 M240i M Performance Edition / xDrive / ZF8 / BM3 Stg 2+ E30 / xHP Stg 3 / Dorch Stg 2 HPFP / Evolution Racewerks Catless Downpipe / MPPSK Exhaust / FTP Drop in Filter / FTP Intake Pipe / FTP Chargepipe / NGK 94201 Spark Plugs .022 / Michelin PS4S - 225/35/19 + 245/30/19
      05-18-2020, 07:49 AM   #21
GrandMasterKhan
honestly my setup fit well. Yours will be 13.5 mm more aggressive and with wider tires you will hit the fenders for sure. you'll probably need an aggressive roll in the front and more camber all around.
      05-18-2020, 08:18 AM   #22
SkyeC
Too many cars, not enough time
43
Drives: 17 m240i
Nice. Looks great. So now we know 18x8 45 245/35 is a go.
