08-30-2017, 03:30 PM | #1 |
Rep 9,788
Quick Question for MS Office Experts
When copying and pasting Excel over to PowerPoint, is there any way to allow users to select and copy the data while NOT allowing them to edit the excel chart? Pasting as pictures doesn't allow for selection. Pasting as source format allows people to delete the data. Marking as final doesn't work either. Also tried protecting the sheet and workbook before copying over to PPT and that doesn't work.
Google says there's no way but I figured i should ask with folks on here before giving up. Lol |
08-30-2017, 04:29 PM | #2 | |
Smiling Politely
1524
Rep 29,119
Make the xls read only.
Although that wouldn't help you when it gets to ppt. You could leverage rights management and remove editing abilities but then they wouldn't be able to copy.
08-30-2017, 04:52 PM | #4 |
Rep 9,788
Yeah, I'd like to be able to paste as chart to allow highlighting/selection and copying and pasting but I don't want people to edit the data. I'm just curious if that's even at all possible.
08-31-2017, 12:23 AM | #5 |
Rep 4,209
Drives: '13 F10 M5 | '15 F15 X5
After playing around with PowerPoint, I'm afraid there are no "Lock" concept in PowerPoint. You'll just have to trust in them to not edit the slide containing the data.
08-31-2017, 04:31 AM | #6 |
2JZ-GTE
3146
Rep 4,112
Yes
08-31-2017, 08:16 AM | #7 |
Rep 4,365
Drives: '07 Z4 Coupe, '21 X3, '16 GMC
Macros are not as reliable in PPT just due to them not being used as much but I am sure there is a way to check for changes in an object and not allow them like there is in Excel. That would be the only way I can think of in PPT and I don't have code for it offhand so it would be up to you.
2007 Z4 3.0si Coupe • 6 MT • Black Saphire Metallic • PP • SP
2016 GMC Sierra SLT Z71 Premium Plus 4x4 2017 Harley StreetGlide • Denim Black • V&H Tune 2021 BMW x30i • Phytonic Blue Metallic • Fully loaded |
08-31-2017, 09:08 AM | #9 | |
Rep 474
Drives: 2014 328D xDrive
1. Select the data you want in your excel sheet and copy it 2. Go to your powerpoint, right click on it, and select "embed" as the paste option 3. open the data in powerpoint by double clicking on the embedded data 4. Select all the data, right click, and select "format cells" 5. Go to the far right tab labelled "protection" and ensure the "locked" radio button is checked 6. with your embedded data still selected, go to the "review" tab up top (this is currently the excel review, rather than powerpoint review since you have the excel data selected) 7. On this tab, select the icon for "protect sheet" 8. Ensure the top box is checked "protect worksheet and contents of locked cells"; then in the box below check "select locked cells" and "select unlocked cells" 9. Add a password if you like, just be sure it is one you will remember. Without a password, your users will still be able to edit the data if they take the time to unlock the sheet. 10. Save your work. After following these steps, you or anyone will be able to copy and paste the date out of the embedded excel, but will not be able to edit the original data in the powerpoint without unlocking the sheet first. |
08-31-2017, 09:39 AM | #10 | ||
MUHAAHAA
236
Rep 610
I tried creating a pivot table for the source data and then locked both the source data sheet and the pivot table sheet - proceeded to copy a random graph from the pivot table sheet (under permissions while locking the pivot table sheet you got to allow users to use the auto filter, pivot chart and edit objects though) and used paste special as keep source formatting and embed workbook option. Every time I tried to edit the data it prompted that the sheet is locked so I think it works and it still lets you copy data into another application while the users can play around with the data all they want and change the graph as well to their own liking. |
08-31-2017, 09:50 AM | #11 | |||
MUHAAHAA
236
Rep 610
08-31-2017, 10:00 AM | #12 | ||||
MUHAAHAA
236
Rep 610
PM me if you have questions. |
08-31-2017, 03:17 PM | #14 |
18326
Rep 9,410
Paste as data instead of paste as link? That way you get a copy but no link to the original data, so nobody viewing the ppt can edit the excel sheet.
Caveat: the last time I did it this way, it was Office9x, so YMMV. |
08-31-2017, 03:18 PM | #15 | |||
Rep 9,788
08-31-2017, 03:20 PM | #16 | ||
Rep 9,788
08-31-2017, 03:28 PM | #17 | |
Rep 474
Or am I misunderstanding your issue? |
08-31-2017, 03:32 PM | #18 | ||
Rep 9,788
Looking at it, i don't think this works as I'm working from a master file and only want to insert a portion of the chart for others to see. When I embed stuff, they can see all the tabs in the file I have (I don't want this). |
08-31-2017, 03:33 PM | #19 |
Rep 9,788
No options for that. At least not that I know of.
08-31-2017, 03:36 PM | #20 |
Rep 474
What exactly are you pasting into the ppt? An entire spreadsheet or a selected group of cells within a sheet?
08-31-2017, 03:42 PM | #21 |
Rep 9,788
08-31-2017, 04:23 PM | #22 |
Rep 474
OK got it. So yeah, you'll need to copy the sheet you want them to see into a new file so they can only see the one. Then locked it will still allow them to copy but not edit.
