02-04-2019, 10:38 AM | #991 |
Rep 6,073
Appreciate your intent, but it's not a competition, nor a challenge. Given the detrioriation in post #984, I've relegated it to a dismissal. As said earlier, everyone can reach their own conclusions, no matter how diverse, understanding the risks/benefits.
02-04-2019, 01:16 PM | #992 | |
Rep 318
The dew point is the temperature at which air holds all the water vapor it can. If the temperature is reduced further, some of the water vapor condenses - into suspended droplets as fog or cloud, or onto any surfaces it contacts. When the air conditioner compressor is running, the surfaces of the evaporator coil (heat exchanger) get very cold (that's how it cools the air flowing through it). Air touching the coil is cooled well below the dew point, unless the relative humidity is extraordinarily low. In most places in North America, at temperatures high enough that air conditioning or dehumidification is desirable, condensation is forming on the coil whenever the compressor is running. That condensation builds up on the coil until it runs off onto the housing and eventually out the drain port. When the compressor stops the system warms up to above the dew point, condensation stops forming and gradually the water dries out. However, if the engine is stopped before the HVAC system is dry, the water can escape only by diffusing out through the ducts and vents, which is a very slow process (hours to days, not minutes). Until it is dry, any mold spores in the water start germinating and if left there will attach to the system and grow a bit whenever more moisture is added. Now, if you run AC all the time in humid conditions, so much condensation forms and runs off that it flushes away any mold spores and recently germinated spores before they can attach and start growing. This is, I think, why using the Auto setting can work to prevent mold under those conditions. It's a different story where I live. It's never humid enough that using the AC to dehumidify is appropriate (unless it's raining), and air conditioning is needed for roughly one day in three for four months a year. Since my car often sits for a week at a time, it is critical that I get all the water out of the HVAC system before I turn the engine off. The manual says that in Auto all the incoming air is first cooled and dehumidified (whether it needs it or not), then warmed if needed. That means condensation is forming inside the system nearly every time you start the engine. But when the outside air is cold it holds very little moisture, so there probably isn't enough water formed to flush the system of mold spores reliably. Just enough to get them growing. That's why I would rather have the air conditioner off unless I actually need it. Then I can make sure the system is dry before I stop the engine for what might be a week or two. (And that's why it's so annoying to have the compressor turn on when all I want is heat on the windshield. I have to make sure I drive around for a while with defrost off to make sure I dry out the system before stopping.) There's also the issue that the compressor draws up to 1/3 hp, which is not completely trivial since it takes typically less than 25 hp to maintain highway speeds.
18 M240i RWD auto
Previous: 01 Z06, 99 323i Last edited by albertw; 02-04-2019 at 02:06 PM.. |
02-04-2019, 07:07 PM | #993 |
Rep 141
I appreciate that you reveal early in your post that you are a condescending prick. It saved me from reading the rest.
Just curious though, why do you think anyone would read anything from you since you are, after all, merely another "anonymous forum poster"? |
02-04-2019, 09:39 PM | #994 |
Rep 318
I try to give back what I receive. When someone says over and over again that I'm wrong without ever saying why or really explaining his position, then turns out not to even understand the very basic physics of the issue he's pretending to be an expert on, I figure I have the right to be condescending right back at him.
18 M240i RWD auto
Previous: 01 Z06, 99 323i |
02-05-2019, 09:57 AM | #997 | |
Rep 100
02-05-2019, 10:44 AM | #998 | |
Rep 400
Hit Auto button (AC light will lit), then push AC button. AC compressor will remain off unless you manually choose defrost/defog mode. As an mobile HVAC engineer, I know for the fact that Auto mode can perform the best for 99% of people. However, HVAC is not only about working ideally. It's all about personal preference. Some want hotter, the others want colder...etc These days, we do develop systems that work the best in Auto mode. It still works fine in manual mode and no harm will be there. (but Auto is better controlled) For the most automotive AC system, AC compressor will run almost all the time in Auto mode. However, AC compressor will NOT run if ambient temperature gets below certain temperature (varies by manufacturer) to avoid icing on the evaporator. I've noticed that the AC compressor in my car runs in 25F ambient. This is possible because the partial re-circulation. Even in fresh air intake setting, there can be partial warm air flow from interior, goes through evaporator. This is mainly to dehumidify the interior to prevent fogging. Typical human exhalation emits about 70 grams of moisture per hour. HVAC system needs to take care of that to clear the windshield. BTW, AC compressor in our car is something called "variable displacement compressor". It does not have clutch. Depends on compressor demand, compressor can vary it's output hence it can run very efficiently. When it's cold outside, it will not draw much power (less than 1 hp). (It can take up to 5~7 hp when it's very hot outside) So, all the air always goes through evaporator first (regardless the compressor is on or off), then it goes through heater core if hotter air is desired. The air gets colder and drier after the evaporator, then heated through heater. This way, it can defog effectively. Just blowing hot moist air to windshield will take more time for defog. For mainstream cars, there is no "adding humidity" function. (some ultra luxury cars may have humidifier) For the condensation management, all the evaporators have water repellent coating as well as anti bacterial coating. These coatings typically last about 2~3 years. That's why you start to smell after couple of years. Some GM cars have 'after blow' functions to dry out the evaporator after the car is turned off. Most cars, if you leave in Auto, molds can be somewhat washed out more often with condensation since AC compressor is running more frequently. Last edited by TajoMan; 02-05-2019 at 08:31 PM.. |
Sportstick4727.50 MasterFloody42.00 |
02-05-2019, 11:02 AM | #999 | |
Rep 400
There is no humidity sensor but we 'guess' based on ambient temperature and how much hot air we need to blend to get to target interior temperature. To defog, the best way is using defrost/defog mode. (which forces Ac compressor running, as long as the ambient is not too cold) Auto mode also works very well to defog. |
02-05-2019, 12:20 PM | #1000 |
Everyday I'm shuffling
449
Rep 1,098
02-05-2019, 01:13 PM | #1001 | |
Rep 277
Drives: 2018 230i MSport
02-05-2019, 01:31 PM | #1002 | |
449
Rep 1,098
Changes the car completely. |
02-05-2019, 02:15 PM | #1003 | |
449
Rep 1,098
02-05-2019, 03:30 PM | #1004 | ||
Rep 277
02-05-2019, 04:15 PM | #1005 | |||
Rep 109
02-05-2019, 04:20 PM | #1006 |
Rep 6,073
I questioned BMWNA about this a few years ago, as my wife complains as well, about its absence. They received feedback from Munich that aftermarket installation is not feasible due to the placement of the side curtain airbag module.
Mehim76.50 |
02-05-2019, 06:06 PM | #1007 | |
Rep 100
Nice explanation, by the way. |
TajoMan174.00 |
02-05-2019, 08:32 PM | #1008 |
Rep 400
02-06-2019, 07:07 AM | #1010 |
3708
Rep 3,621
02-06-2019, 11:27 AM | #1011 |
Rep 100
When I checked the coding for the headlight washers on mine, they were set to activate after 10 washes. I was wondering why they hardly ever activated. Have set them to 5 now, but they don't activate on the first windshield wash, only after 5. Probably that's also a coding issue, I don't know. In any case, no more headlight washers are being installed in the 2 series anymore anyway. I find them useful, especially with the amount of salt on the roads around here recently.
02-06-2019, 12:03 PM | #1012 | |
Rep 318
You might want to ponder, if you're capable of it, a conversation I've had a number of times: Me (intending to commiserate): What have you tried to fix the moldy smell coming out of the vents? Owner of older car: What moldy smell?
18 M240i RWD auto
Previous: 01 Z06, 99 323i Last edited by albertw; 02-06-2019 at 12:18 PM.. |
