2Addicts | BMW 2-Series forum BIMMERPOST Universal Forums General BMW News and Cars Discussion Adaptive headlights not turning (no codes)
      10-21-2021, 04:33 PM   #1
chef423
Drives: E90
I just replaced both of the SMC modules (both were corroded and giving error codes) and coded them in with PROTOOL but the lights still wont turn left or right...
I notice when I start the car the lights do move up, adjusting up a bit.
I re-coded both the left and right to see if that would fix the issue but no luck.
Any ideas?
Thank you,
Chef
      10-22-2021, 02:57 AM   #2
ptpending
ptpending's Avatar
456
Drives: e91
do you remember that they are turning only when light switch is in auto mode ?
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes.
      10-22-2021, 06:25 AM   #3
sergiyny
Drives: BMW X5 M Sport
as far as i know they only turn right...
      10-22-2021, 09:31 PM   #4
chef423
Drives: E90
I dont remember (not sure what you are asking)
I could have sworn before when they were working they moved both directions when I turned the wheel left or right, respectively. I do keep my lights in Auto Mode, yes.
      10-22-2021, 10:20 PM   #5
DenverSteve
DenverSteve's Avatar
969
Drives: 2021 BMW
That would be totally incorrect. Left and right.
Originally Posted by chef423 View Post
I dont remember (not sure what you are asking)I could have sworn before when they were working they moved both directions when I turned the wheel left or right, respectively. I do keep my lights in Auto Mode, yes.
You would be correct.
      10-22-2021, 11:42 PM   #6
chef423
Drives: E90
No codes and new parts. Still have no idea why they are not turning....OR how to troubleshoot.
Help.
      10-22-2021, 11:59 PM   #7
LOW4LYF
LOW4LYF's Avatar
2163
Drives: E92 M3 & F85 X5M
They turn right only if the vehicle is not moving. If you driving they turn left and right of course.
      10-25-2021, 05:28 PM   #8
chef423
Drives: E90
I wish they turned, at all!
      10-26-2021, 06:36 PM   #9
chef423
Drives: E90
No one?
      10-28-2021, 08:01 AM   #10
DenverSteve
969
Drives: 2021 BMW
No codes and new parts. Still have no idea why they are not turning....OR how to troubleshoot....Help.
Too many possibilities: incompatible parts, bad ground, blown fuse, too much corrosion, you f(#$ed something up.....??
Solution - take it to your dealer if they work on older 3-series cars (some don't) or your independent. It probably could have been fixed by now.
The #1 rule that works "for me" is - don't try to be a German-car mechanic if you're not a German-car mechanic. There are too many interconnected electronic items on newer cars.
#2 is - Don't buy an older German car without setting aside $1,000-$2,000 a year for professional maintenance. Not total - per year. You will eventually need it.
      11-03-2021, 12:13 PM   #11
chef423
Drives: E90
Bought the car and have updated about 8k worth of parts. So im all in. I bought this car for that reason. And I am German, but i dont need that title to be able to work on this car.
Looking for additional input from EXP wrenchers.
      11-03-2021, 12:45 PM   #12
DenverSteve
969
Drives: 2021 BMW
Yeah. As you've already figured out - being German hasn't helped yet.
      11-03-2021, 12:49 PM   #13
rcracin
Drives: M3
Try reading through this:
https://www.e90post.com/forums/showthread.php?t=1117724
      11-05-2021, 02:17 PM   #14
chef423
Drives: E90
Neither has these forums, ironically. And I would never pass my car to a 'mechanic', that's insanity. I do ALL my own work, no matter the difficulty level. Funny how refreshing the Transmission is easier than figuring out why my lights wont move.
      11-05-2021, 03:05 PM   #15
rcracin
Drives: M3
This forum doesn’t owe you anything. Your attitude definitely doesn’t help. Good luck
      11-05-2021, 04:59 PM   #16
1and1
Loves me some MHD!
1and1's Avatar
Drives: faster than he should...
'09 135i  [10.00]
Chef,
Is this correct-
-You replaced the smc modules
-You coded with protools
-You then had no codes, but no l/r movement
-You then recoded with protools with no change to the symptoms
Presuming still no codes
OK then, what else have you tried? Verified mechanical function is correct? Checked the coding with anything else but pt? Located a donor set of lights to test with, to really verify yours aren't borked? Verified wiring is all good?
I'm guessing you've actually done all those things already, cause I'm sure a hotshot wrench like yourself isn't asking to be spoonfed. Yes, that was meant to sound bitchy.
Hey, I don't know what the heck is up with your lights, and I do my own wrenching too. But if my headlights were doing the same thing I'd be a lot more active to get it fixed than pestering a forum two weeks later.
If you are leaning in on coding, why not alter the approach and look into what coding to review, and which tools are best to investigate with? You know, instead of asking what's wrong. I'm not a coding hotshot and have no idea where to look or suggestions to offer, but, again, if it were me that's probably what I'd be doing.
And I'm not kidding about a donor set of lights to test with, you'll know instantly which half is borked, hardware or software.
1and1
135i - E82.N54 2009 BSM - MHD / xHP / DCI, PR CP & 7.5" Race IC / N55 mid & Borla
. . WL RSFI, Koni, Eibach & Dinan CP's, M3 CA's / EBC Red's & Firehawk 500's
X1 - E84.N20 2013 MGM - JB4 - The Wife's, now with new turbo & ewg
