| 04-20-2025, 02:14 PM | #1 |
![]() 117
Rep 257
Garage clean out M235i OE parts
Title says garage clean out but it's actually my living room full of boxes. Everything has between 39-45k miles and worked fine when removed unless otherwise noted. Figured I'd give you guys a shot at this stuff before I put it up on ebay. N55 stuff: OE charge and boost pipes, including the charge pipe bracket. OE Cat converter, no light when removed, 39k miles. OE intercooler OE blow off valve, worked perfectly when removed. Logged 20psi a few times before I removed it. *EDIT*OE HPFP 50k miles Exterior: Kidney grilles with chrome trim Mirror turn signals OE white LED headlamp halos Passenger F87 mirror with indicator, no cap, no glass. *EDIT* Stock grey rear diffuser Suspension: Full OE spring kit Front upper strut plates 40k miles OE front strut brace Accelerometers from the OE EDC front struts. I was going to hack together an EDC delete kit but decided to just code it out in the end. Zimmerman 2NH 340mm front brake rotors, dimpled and slotted less than 2k miles, annoying cricket noise when driving. Good cheap track rotors. *EDIT* Complete set of brakes with less than 5k miles on it, including brand new rear parking brake shoes OE aluminum shift paddles OE transmission mounts 41k miles, look perfect. Prefer to sell this stuff in batches, local pickup or shipped is fine. Everything removed by me, all clips and brackets in tact and undamaged. Last edited by Coupsoup; 11-20-2025 at 01:49 PM.. |
| Bookmarks |
| Thread Tools | |
