10-11-2023, 06:16 PM | #1 |
Rep 36
XDrive Question
I might be getting a 2015 m235i xdrive but I have never looked into the system. Is it reliable? Is there extra maintenance I would need to do? Do they have an lsd? Im an awd noob if you couldnt tell lol. Any info is appreciated.
10-11-2023, 06:50 PM | #2 |
Rep 559
It is a lot more moving parts that a RWD car, but you don't need an LSD as it is very hard to spin a tire with four wheels being driven. It is also a lot of added weight with the transfer case, extra differential, CV joints and drive shaft.
Having said that, I ordered mine with xDrive and love the way it handles. |
10-11-2023, 07:35 PM | #3 |
E4 Mafia
350
Rep 432
It's a pita to service. No drain plugs.
Squad - '90 E30 325i MT (226k) | '98 E36/5 318ti MT (160k) | '03 E46 325i MT (156k) | '04 E46 330xi MT (195k) | '15 F22 M235i MT (66k) | '15 F30 335i MT (85k)
KIA - '91 E30 325i AT (146k) | '02 E46 325i MT (212k) Bring back the purple M stripe |
10-11-2023, 07:52 PM | #4 | |
Rep 36
10-11-2023, 08:17 PM | #5 |
Rep 676
X-drive is very reliable and performs well. It does add some weight, but the extra traction is worth it to me. I drive mine in winter conditions and don't even worry about having the traction I need.
10-11-2023, 08:52 PM | #6 |
Rep 559
10-12-2023, 09:02 AM | #7 |
Rep 6,352
I completely understand the point you are sharing to help the OP who self-describes as new to having a vehicle that powers all 4 wheels, so please let me make a detailed additional point here. AWD/4WD systems don't generate any additional traction. They simply send power to all 4 wheels. All traction occurs at the contact patch where the tire meets the road, not in any part higher up in the car that doesn't touch the ground. If the tires hypothetically were so worn and on ice such that the contact patch had an also hypothetical zero traction, it would not matter if the car powered 1,2,3, or all 4 wheels. It would stand still with wheels spinning. Tires are the critical factor, OP! The reason for being this literal is that if the OP has some use for XDrive, such as going from a mild California climate into ski country in the winter, he/she, as new to this powertrain configuration, should not assume XDrive alone will suffice. I saw a lot of this fallacy in Michigan winters with typical SUVs alongside highway ditches. A news reporter once did a story and people thought AWD would save them and they did not use winter tires.The traction comes from the tires and winter tires would still be needed. If the OP doesn't have such plans, then all of this conceptual discussion is not actionable, but may help put XDrive into perspective for him/her.
2024 X3 sDrive30i/MSport/Premium/Dynamic Handling/Shadowline/Parking/Xpel Prime XR Plus/Weathertech Cargo Liner Last edited by Sportstick; 10-12-2023 at 10:38 AM.. |
celsdogg350.00 |
10-12-2023, 08:40 PM | #8 |
Rep 81
Yes, xDrive is reliable and extremely capable in bad weather. But, personally, I'd only recommend getting it under at least 1 of 2 conditions:
1) You really do need the extra forward traction 2) You will get rid of the car before any real maintenance on the system is necessary (namely, replacing seals and gaskets), or you don't mind paying extra for the work. There are trade offs for that forward traction. The car is heavier. It does worse on fuel. There are more moving parts in the driveline, so less power makes it to the wheels. Any maintenance to the drivetrain or the underside of the engine is more complex and expensive. Oil pan gasket, wheel bearings, transmission seals, rear main seal, etc. Also, consider tires. They need to be the same rolling diameter at all 4 corners, which will dictate your choices for rubber. And if there's ever a failure/puncture, you may have to get an entire new set. xDrive cars come with 7.5" 225 width all around. RWD gets the staggered setup with 8" 245 rears. And the driving feel is quite different. With xDrive, you can feel the system shifting power around. RWD is more direct and feels more responsive to throttle input while cornering. So, the xDrive car has more weight to throw around in corners, is slower and less direct, and is less fuel efficient and more expensive to maintain. However in the snow, xDrive is a *monster* compared to RWD. I've DD'd both in New England winters. I got by totally fine in snow storms with my old RWD E46. But my 328xi is *unstoppable* in the snow, and it's nice to have that confidence and peace of mind. Drive both iterations and see if the tradeoffs are palatable for you. They aren't huge, but it adds up to a car that feels quite different. Most of us only really use AWD max 5% of the time the car is being driven. I'm in CT and I'd say I use my xDrive less than 1% of the time I'm driving the car (I say this as I use xDelete to run the car in RWD whenever I'm not driving in snow). RWD = max response in driving dynamics, better performance and efficiency, easier to maintain when the time comes. xDrive = still has awesome performance and drives nice. Peace of mind for snow driving, but it comes at some expense that only you can prioritize for your use case. |
10-12-2023, 08:52 PM | #9 | |
Rep 676
10-12-2023, 09:00 PM | #10 |
Rep 6,352
As long as you aren’t in winter weather, you should be fine. If you are in winter weather and rely on XDrive instead of proper tires to stop/turn when an unexpected event occurs, you probably won’t be fine. That’s the point the OP needs to understand.
fiveightandten111.00 celsdogg350.00 |
10-12-2023, 09:19 PM | #11 | |
Rep 81
A RWD car on winter tires will often accelerate in snow better than an AWD car on all seasons...and it will stop and corner better 100% of the time. |
harma24411.00 |
10-13-2023, 06:51 PM | #12 |
Rep 676
That's absolute crap. Lived in winter weather all my life, driving in it for 47 years. The real trick is to be a competent driver, but even the less competent ones somehow survive without winter tires. Not saying winter tires aren't good, they are, but they sure as heck ain't necessary.
10-13-2023, 06:56 PM | #13 | |
Rep 676
10-13-2023, 07:42 PM | #14 | |||
Rep 759
That's not to say that it's not entirely possible to drive in the winter on a decent set of all-seasons. I did this with every car before my M240 (and still do on my minivan). The only reason I have winters for my M240 is so I can put a good set of summers on it instead of having to compromise with all-seasons.
Kernel Kurtz358.50 |
10-13-2023, 07:52 PM | #15 |
Rep 6,352
OP, read and decide as your judgement guides you. Keep in mind, of the three things a car does...go/turn/stop..."go" is the least relevant to your well-being, especially when one of the less competent drivers unexpectedly slides or skids into your path. XDrive won't save you then. Tires can. If you get an XDrive vehicle, just don't assume you can therefore reasonably rely on less capable tires. Of course, we never established whether you drive into winter climates. If you don't, Xdrive's negatives outweigh the benefits in mild climates.
2024 X3 sDrive30i/MSport/Premium/Dynamic Handling/Shadowline/Parking/Xpel Prime XR Plus/Weathertech Cargo Liner Last edited by Sportstick; 10-13-2023 at 08:36 PM.. |
10-13-2023, 10:14 PM | #16 | ||
E4 Mafia
350
Rep 432
10-14-2023, 01:27 PM | #17 | |
Nobody in particular
126
Rep 127
Sportstick5059.50 jzeiler4335.00 |
10-15-2023, 05:42 PM | #19 |
Rep 36
[QUOTE=fiveightandten;30565768]
Drive both iterations and see if the tradeoffs are palatable for you. They aren't huge, but it adds up to a car that feels quite different. Most of us only really use AWD max 5% of the time the car is being driven. I'm in CT and I'd say I use my xDrive less than 1% of the time I'm driving the car (I say this as I use xDelete to run the car in RWD whenever I'm not driving in snow). That xdelete seems interesting. Ill def have to check that pout as well. |
