2Addicts | BMW 2-Series forum BIMMERPOST Universal Forums General Automotive (non-BMW) Talk + Photos/Videos Toyota develops Hydrogen Fuel ICE
      05-11-2021, 11:31 AM   #23
5.M0NSTER
5.M0NSTER's Avatar
Drives: 2018 Camaro SS 1LE
Originally Posted by JamesNoBrakes View Post
It's only "clean" in the combustion process. You gotta look at the whole picture.
There, you just summarized my whole problem with EVs. Sure, they don’t make any emissions. But the coal or NG power plants charging them do in spades.
Also name a driver’s choice, or objectively fun EV. And if you say Tesla I’m going to lough. Let's hear it.
Germanauto9701.00
      05-11-2021, 12:17 PM   #24
mkoesel
Moderator
Drives: No BMW for now
Those types of energy generation facilities are being gradually replaced with less polluting ones just like combustion vehicles are gradually being replaced with cleaner, more efficient ones. But you're right - we shouldn't single out hydrogen production as non-clean when the same applies to dozens of other processes used to obtain, refine, and deliver raw materials needed to produce and assemble vehicles as well as the various types of energy that power them.
Indeed that's why there are also efforts to create liquid hydrogen using clean energy. This will address much of the hand flailing that currently occurs when hydrogen production is discussed. Sure, that still leaves the fact that it is say (for the sake of argument) only about 1/3 as efficient as using the electricity to power vehicles or homes (or whatever else) directly. But who cares? If I want my windmill farm to waste 2/3 of their potential producing liquid hydrogen instead of powering a city, that's my prerogative. It's exactly this reason that hydrogen cannot be guaranteed to be the dead end that many people believe, and it's also why shorting the entire hydrogen sector on the basis that "But it's not green!" would be a very bad move right now. Hey, maybe the whole thing does go bust eventually. Who knows? But I dare you to bet against it, right?
Why though, in my right mind, would I waste my windmill farm or solar grid on such nonsense, you might be quick to ask? Because somebody somewhere might be willing to pay me three times as much for that hydrogen to offset the difference for the privilege of being able to refuel their trucks or boats or machines in minutes instead of charging them in hours. On the other hand, no sum of money is going to enable you to charge their batteries at comparable speeds, especially at that scale.
      05-11-2021, 02:03 PM   #25
5.M0NSTER
5.M0NSTER's Avatar
And it doesn't even have to be Hydrogen, it's just one option. This idea isn't terrible either. So the message is we can still IC things, while being CO2 neutral.
2017 BMW M2 German Spec
6MT, Driver's Package
--> SOLD
2018 Camaro SS 1LE. Because race car!
"Redline a day keeps the mechanics away"
      05-11-2021, 03:54 PM   #26
diablo2112
2024 M440i GC (G26)
278
Drives: 2024 M440i Gran Coupe
This idea is perhaps the single stupidest piece of automotive engineering I've read about from a major auto company in 40 years.
Hydrogen is fine. It's a clean power source. We'll eventually figure out production, distribution, and on-vehicle storage options for it. That's not the problem.
The problem is burning hydrogen in an ICE. This is monumentally stupid. ICE technology is the production of useful, mechanical work by use of a heat cycle. More than 150 years ago, Victorian-era engineers figured out the efficiency of heat cycles. The best you can do - ever - is called the Carnot Efficiency. And amazingly, this depends only on temperatures. The hottest you can get your engine, and the coldness to which you expel heat. You're never going to get an ICE to exceed about 40% efficiency because of this, given limitations on materials and achievable temperatures.
So what's the alternative? Extraction of the energy in H-H bonds via electrochemical cells. This isn't new. It's been done for 100 years as well. It's the way nearly every manned spacecraft is powered, including the Apollo missions and the Space shuttle. Hydrogen is the perfect input to these "fuel cells". You avoid a heat cycle completely, and the strangling aspects of the Carnot efficiency. The amount of useful, electrical power you can pull from a fuel cell is well over 90% of the energy available in the hydrogen fuel. And the only emission is water. Water clean enough to drink; this is how water is made during space missions.
Fuel cells are so attractive for automotive use, that the only real issue is fueling them. You can burn carbon-containing fuels in a fuel cell, but the presence of that carbon leads to reaction products (carbonates) that clog the delicate membranes in these cells, quickly rendering them inoperative. The engineer that solves that particular materials problem will become the richest man on earth, btw.
For now, we're stuck with burning hydrogen in fuel cells. The limiting problem deploying this on vehicles is getting enough hydrogen onboard to be useful. Some groups have been working on "onboard reforming" technology that would convert gasoline (stored on the vehicle) into hydrogen with a small, onboard chemical reactor. This has the advantage of using existing infrastructure for fuel.
The other option is to store the hydrogen directly as either a high pressure gas, liquified, or (probably the best option) as a metal hydride, which releases hydogen upon heating. Uranium works great here, but it's heavy. The weight of a uranium hydride bed with useful quantities of hydrogen storage exceeds the mass of long-range Lithium battery packs. And it's violently pyrophoric, another slight problem for vehicle use...
Anyway, Toyota's decision to produce a hydrogen-burning ICE is just catastrophically, insanely bad engineering. Hydrogen is great. It's so great, that we should develop an infrastructure for it. The reason it's great is that when used with fuel cells, it solves most of the problems of batteries and EVs, and avoids the terrible efficiency penalty from using heat engines. Burning that hydrogen in an ICE as opposed to a fuel cell really is that monumentally dumb.
      05-11-2021, 07:36 PM   #27
ShocknAwe
1Addict
ShocknAwe's Avatar
3233
Drives: E82 Mutt, M57 Truck
Because you are extremely biased and subjective to claim that high performance EVs are no fun and it takes a lot more energy to make, compress, store and transport H2, which drives costs up and wastes energy that could be used elsewhere, like for water extraction/transport. It's only "clean" in the combustion process. You gotta look at the whole picture.
Pot meet kettle.
2010 135i 6MT Jet Black
N54/3 FE82 Mutt | BUILD THREAD | GARAGE SALE
      05-11-2021, 07:59 PM   #28
chassis
chassis's Avatar
6536
Drives: 9Y0 Cayenne S
When did lack of infrastructure ever stop a new propulsion technology? I'm looking at you, Tesla.
Hydrogen has ubiquitous availability, it means every nation is a transportation fuel producer. A huge win for the world.
Energy to compress hydrogen, requirement for high pressure systems, and safety/combustability seem to be difficult hurdles to overcome.
I still haven't seen a short, simple, fact-based comparison vs ICE for the entire EV carbon+disposal chain from digging lithium out of the ground, to manufacturing EVs and batteries, then recycling them at end of life.
How is the full EV lifecycle, including batteries, any better than alternatives? The only force driving EVs in my opinion is carmakers' profitability, which is 20%-30% higher for EVs than ICE vehicles due to the lower cost of components and labor to produce an EV.
      05-11-2021, 08:03 PM   #29
VisualEcho
VisualEcho's Avatar
Drives: '18 M2 6MT
2018 BMW M2  [10.00]
I applaud Toyota for trying, the ICE isn't going anywhere, so all avenues need to be explored.
Besides, those guys are way smarter than anyone on here, so don't listen to the Bimmerpost Mafia that think they know it all.
chassis6536.00
Germanauto9701.00
      05-13-2021, 12:16 PM   #30
Efthreeoh
General
Drives: The E90 + Z4 Coupe & Z3 R'ster
Agree with all you said, but BMW built the Hydrogen 7 about 15 years ago. Seems most the the Bimmerheads here forgot?
The idea of on-board gasoline-to-hydrogen conversion is the correct path except some don't like carbon in the conversion process.
      05-13-2021, 12:22 PM   #31
RM7
RM7's Avatar
2893
Drives: Camaro SS 1LE
I didn't because there already was infrastructure, the electrical grid. While it may not be able to support everyone with an EV at the same time, it at least exists, is being upgraded, and can support a good number of EVs in it's current state. That's vastly different from no infrastructure like H2. Mental gymnastics to think it's the same thing. That's kind of the whole point about EVs, you can "plug them in".
Current: 2018 Camaro SS 1LE, 2023 Colorado ZR2. Former: BMW 428i Gran Coupe.
      05-13-2021, 02:39 PM   #32
ptack
ptack's Avatar
Drives: 135i
2008 135i  [6.50]
Time will tell, but this reminds me of the observation the British general Slim made about the Japanese in WW2. He said they were terribly effective at executing a good plan, but became lost if the conditions for that plan were to change significantly. That makes sense when major decisions are based on consensus. It can be very difficult to admit that everyone was wrong in agreeing with the plan. The hydrogen vehicle is a poster child for that. It's a relatively old plan that they have invested huge amounts of money on, but it's a solution that just doesn't have a use right now and frankly it looks like they're just stubbornly refusing to admit this was a mistake. The only way they can even hope to get something out of this is if they can convince the Japanese government to invest untold billions in the necessary infrastructure.
135i, SGM, Coral, Sport Package, Auto, Premium Hifi, USB/ipod, Apex EC-7s, PPK Stage II
RM72892.50
      06-21-2021, 09:38 PM   #33
5.M0NSTER
5.M0NSTER's Avatar
To the points a lot of you have already made, here is a good breakdown by EE.
--> SOLD
RM72892.50
      06-21-2021, 11:52 PM   #34
RM7
RM7's Avatar
2893
Turns out that Toyota got a ton of grant/subsidizing money from the Japanese government for hydrogen development years ago as part of a big alternative fuels push and this continued for quite a while. That's why they were making all the one-off hydrogen prototype stuff. None of this has ever been serious on Toyota's part, just utilizing funds and making something to show for it.
They've been silently working on battery technology and seem poised (based on the video below) to jump on the solid state battery wagon and have electric cars with 2-3x the range of the longest-range stuff on the road today.
I see hydrogen as impractical for most ICE applications, but a few that require more energy density than can be provided by batteries in the foreseeable future, like aircraft and cargo ships (and some others obviously) may make sense. I think long-range trucking will go battery as well, based on the rate of development and with other solutions like battery swaps. It is also not practical to generate an entire supply chain and the required infrastructure to produce, compress and deliver hydrogen to every gas station out there. It's a crazy amount of energy to accomplish this. Electrical infrastructure may not be perfect or capable of just turning a switch and everything all of a sudden going to electric, but it is there, it works and it is being gradually updated as more electrification is happening.
      06-22-2021, 02:39 PM   #35
Teutonic
Teutonic's Avatar
No_Country
2709
Drives: BMW
‘Whataboutism’ mixed with some mathematical strawman for good measure. The scale of damage caused by fossil fuel extraction and use is many many orders of magnitude more than mining issues. Yes, if this is their position, they are wrong. Toyota is literally the only one of hundreds of industrial manufacturers going against hedging development of EV technology. This makes it highly unlikely that they are "right". IMO, Toyota put a lot of resources towards H2 a long time ago and is trying to show some payoff for their development and R&D costs, the classic sunk cost issue.
The electric vehicle will leave scars on the surface of this planet like no other activity before.
The oil is a little baby compare with what mining for lithium and other metals does to this planet.
At least an oil field can be reforested and give back to the nature if properly managed. Mining sites like Russian ones or Peru or Chile with hundreds of square km of lakes of acids will destroy forever the face of the earth.
That's beside the point that producing this electric car leave a bigger environment impact than an ICE vehicle.
Please watch 'Global Warning" documentary
      06-22-2021, 04:29 PM   #36
RM7
RM7's Avatar
2893
What are ICE cars made out of? Metal?
New processes are being developed to extract lithium from seawater.
      06-22-2021, 08:09 PM   #37
Teutonic
Teutonic's Avatar
No_Country
2709
Drives: BMW
Sure.
Please read more, eventually visit these sites.
This is what you electric car does to the world:
Appreciate 4
jmack548.50
kyriian883.50
Germanauto9701.00
      06-23-2021, 03:36 AM   #38
The HACK
Midlife Crises Racing Silent but Deadly Class
The HACK's Avatar
1821
Drives: 2006 MZ4C, 2021 Tesla Model 3
“Welcome to 2004.”
-BMW
      06-23-2021, 07:53 AM   #39
pikkagtr
Go Spurs Go
pikkagtr's Avatar
Drives: 2022 GR Zupra
Sure.
Does Elon know you're posting these ?
      06-23-2021, 10:18 PM   #40
RM7
RM7's Avatar
2893
Sure.
I guess you think the copper mines wouldn't exist otherwise? I'm not sure I see the point here. New processes have been developed that will produce lithium from seawater. You are acting like ICE cars don't use metal, like aluminum, steel, copper, etc.? The mining of aluminum is extremely energy intensive. I could play pictures too and load up the pictures of the tar sands (I've flown over them) in Canada and the massive footprint of drilling and refineries. Ultimately, the EVs are far more efficient than an ICE engine will ever be and people will continue to buy new cars.
      08-13-2021, 02:54 PM   #41
5.M0NSTER
5.M0NSTER's Avatar
Another interesting article about Hydrogen use in US and EU. Good read.
https://www.clickondetroit.com/busin...-clean-energy/
--> SOLD
      08-13-2021, 06:41 PM   #42
Germanauto
Germanauto's Avatar
Drives: Alfa Romeo Giulia, Rosso
Even if Hydrogen is not useful on a commercial scale, I hope it will have some niche viability. If ICE doesn't have a future, and EVs are going to continue being their soul-sucking appliance selves, then at least a few Hydrogen offerings on the market can meet that gap.
Former
-2008 E90 328 black/brown
-2012 Lexus IS250 black/black
5.M0NSTER3353.50
jmack548.50
