07-15-2016, 08:18 AM | #177 | |
Rep 1,753
07-15-2016, 10:42 AM | #178 | |
Rep 465
What makes this most difficult for me is that we just don't have much testimony about how the sound of the different amp possibilities compare with the sound of Eton/JL solution. People with the Eton/JL seem to be happy. People with 3rd party amps seem to be happy. I'm happy everyone's happy. But I'd sure like to play music in an Eton/JL car with HK amplification and hop right over to test the same music in a 3rd party amp car. Then I'd know for myself whether the additional investment in an amp would be worth it for me, especially since the cheaper, stock HK amp setup sounds pretty good. Last edited by selmeralto; 07-15-2016 at 11:41 AM.. |
07-15-2016, 11:54 AM | #179 | |
Rep 447
07-15-2016, 01:50 PM | #180 | ||
Rep 1,753
To be honest with you, I listen to podcasts 90% of the time and for that even the Hi-Fi system is perfectly fine. As such, audio is likely the last thing I'll play with, but I still want to keep up to date on my options should I decide to sprinkle in some audio mods in between performance and cosmetic mods.
07-19-2016, 08:36 PM | #181 |
Rep 30
I just wanted to add to this great post.
I installed the rear speakers, JL c2-400x and disconnected my center speaker today, and the instructions posted here and settings posted here were so helpful, making it so easy to do (30 mins~) I wanted to say thanks, and also re-confirm that this is a GREAT upgrade to the overall sound quality, specifically in sound clarity and sound stage in this vehicle, it is a no brainier upgrade. Thanks all! |
07-20-2016, 03:00 PM | #182 | |
Rep 465
07-21-2016, 09:45 AM | #183 |
Rep 71
HK system mods
I installed the bypass harness several months ago with a marked reduction of the dull drone of the ASD.
Disconnected the center channel about 6 weeks ago and got an immediate reduction of harshness with better distribution of sound. Last weekend replaced the OEM speakers in the rear with the recommended JL Audio speakers. So far, this has been the most significant change with much enhanced mid range and a further reduction of higher end harshness. It it so much better that think I might have been satisfied enough to stop at this point. But, there is some remaining harshness with some music at volume and I have the Etons. Planning to install those in the next week or two and looking forward to another improvement. Question re sound deadening. I purchased some weather seal (https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 ) and Dynamat for the Eton installation. I assume the weather seal should be used around the perimeter of the speakers to enhance the seal? Correct? I am planning to place Dynamat on the outer door metal behind the speakers. Any other advice about how and where to use this when the door panels are off? As many have said this is one of the most useful threads on the Forum. Thanks again to all who have contributed. |
07-21-2016, 10:17 AM | #184 |
Rep 14
Hello All,
I've followed the suggestions in this thread and have completed the following in my m235i - disconnect front center speaker - disable ASD (coding method) - replace rear speakers with the JL ones I noticed immediately a difference with the disconnected front speaker - much better stereo effect. With the rear speakers, I was really surprised at how much lower in volume they are than the front speakers. Yes, I can adjust them by using the fader and the volume, but it's a bit unsettling to have to adjust so far from neutral to get it to sound right. Also, the volume seems to reset lower every time I start the car so I'm continually having to push the volume up to 2/3 to hear anything. I was careful to be sure that the red striped speaker wires from the car harness went to the + terminal on each speaker. My question is if there is a way to do any coding to the pre-amp to adjust rear pre-amp outputs so that when I have the fader set to neutral, it really is neutral? Alternatively, is there a way to code the maximum start-up volume setting? |
07-21-2016, 11:24 AM | #185 | |
Rep 2,942
The Dynamat mod is really a matter of taste and ease -- you could do the whole inside of the door if you want, but that would add several pounds of weight. At a minimum you should cover the exposed metal area around the speaker for several inches away from the rim -- including part of the other side of the metal, facing the window. To do this: - install the Dynamat so that it covers the hole completely - Use a razor blade/X-Acto knife to cut a 1- to 2-inch diameter hole out of the center of the Dynamat that covers the hole - Use the blade to cut the remaining Dynamat into 6 to 8 'pizza slices', from the existing Dynamat hole to the rim of the metal speaker hole - fold the slices inward CAREFULLY so that they stick to the inside surface of the metal (the surface that faces the window) - Use a screwdriver handle or similar to smooth out the folds against the metal speaker hole rim. (DO NOT use your fingers; the aluminum will slice right through your skin!) The weatherstripping should be installed on the driver itself no more than 1/2 inch outside the rubber surround. When you take the door panel off, note the plastic flange that surrounds the speaker grille opening and use that as a guide; ideally you want the weatherstripping to seal with that flange as closely as possible. Good luck; let us know how it goes!
CharlieVictor29.50 |
07-25-2016, 02:16 PM | #186 |
Rep 465
Another field report about the extent of the flash problem: JohnnyCanuck reports that he had a Technics ASD harness in his car when he had an iDrive reflash and there was no problem.
Increasing evidence that the harness and and at least some flashes play well together. JohnnyCanuck didn't have an ECU flash done. But it's looking increasingly likely that the ASD harness is OK, that the 3rd party amp is the culprit for flash aborts, and that the setup recommended in this thread is safe with regard to reflashes. Last edited by selmeralto; 08-02-2016 at 07:33 PM.. |
07-25-2016, 02:31 PM | #187 |
Rep 1,202
I've been meaning to post this in this thread in case anyone else is curious. So part of me regrets getting the Bavsound Ghost Subs, but after upgrading the rear speakers and fading the sound rearward, this has an unintended consequence of letting the improved frequency response shine. I can't comment on if I still had the stocks in, but without the harshness of the fronts overbearing the rest of the soundscape the underseat subs are really doing a great job. This car still needs a proper sub though.
I'm aware that technically the subs go quieter as you fade back, but I think I found a good compromise between sub level and frontal harshness. Speaking of a sub, I've got a Rockford Fosgate P300-10 burning a hole in my garage from an old install. Does anyone have the wiring out of the sub so I tap the rear rear speakers without having to run wires to the actual rear speakers? In return I'll do a full sub DIY here. |
07-27-2016, 03:10 AM | #190 |
Rep 5,538
07-27-2016, 08:57 AM | #191 |
Rep 465
07-27-2016, 10:56 AM | #192 |
Rep 5,538
07-27-2016, 12:57 PM | #193 |
E90 M3 and Z4 35i
28
Rep 61
speaker replacement
I have been following the thread and have bought the Etons for the front and the JLs for the rear. However, I have a cab not the coupe. My rear speakers on on the side panels are component drivers like the fronts, not coaxial speakers like the JLs. I have ordered the component matching tweeters to solve the difference. Just wondering if anyone else has attempted speaker replacement on the convertible compared to the coupe?
07-27-2016, 02:35 PM | #194 | |
Rep 2,942
While the subs' speaker-level input would be convenient since it's summed, that unit you have has stereo speaker-level inputs, so it's kind of moot. I'd just use the rears.
07-27-2016, 03:02 PM | #195 | |
Rep 447
07-27-2016, 04:55 PM | #196 | |
Rep 1,202
Viffermike1753.00 |
07-27-2016, 08:58 PM | #197 |
E90 M3 and Z4 35i
28
Rep 61
Thanks to dog for the reply, appreciated. The speakers level is mid panel, similar to front panel, the matching tweeters were on sale on the JL website for 100.00 even. Having them professionally installed. I think it was worth the investment. Will keep all informed on the outcome
07-28-2016, 09:59 AM | #198 |
Rep 120
Can the audio frog 4 inches be used a hk 228i with out adding any extra power? I have no issue getting the tried and true jl/eton but I love researching options. Great thread.
