2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack Anyone running 235s or 245s square setup on xdrive m235i?
      04-03-2020, 05:02 PM   #1
GrimJaw
GrimJaw's Avatar
104
Drives: 2015 M235i
If so please share your thoughts/setup/experience.
      04-03-2020, 06:23 PM   #2
ifobd
ifobd's Avatar
32
Drives: 2017 M240i xdrive
MPS4S in 245/35 on 18x8.5 et38
Dinan springs
No rub
GrimJaw103.50
      04-04-2020, 12:32 PM   #3
Raymondo1234
Raymondo1234's Avatar
Drives: 2016 M235xi
235/40/18 on apex 8.5 wheels et45. KW V2 coilovers.
Camber 1.9 front (kmac camber bushings) 0.04 toe
1.5 rear 0.08 toe
Needs at least 3mm spacer at the front.
GrimJaw103.50
      04-04-2020, 04:46 PM   #4
GrimJaw
GrimJaw's Avatar
104
Drives: 2015 M235i
1.5 rear 0.08 toe
No rub at all?
      04-04-2020, 04:48 PM   #5
Raymondo1234
Drives: 2016 M235xi
1.5 rear 0.08 toe
No rub at all?
No none at all. I have 3mm spacers on the front to clear the struts. I had dinan springs before that and again it was absolutely fine.
GrimJaw103.50
      04-19-2020, 08:19 AM   #6
Fermelmehue
Drives: 228i xdrive
I'm running 235/40/R18 on 8.0" +45 square on 228i xdrive. No rubbing, no poke at all.
GrimJaw103.50
      04-19-2020, 08:21 AM   #7
GrimJaw
GrimJaw's Avatar
104
Drives: 2015 M235i
Wow really? That's awesome what wheels are you using? Any noticeable difference vs the stock 225s?
      04-19-2020, 08:31 AM   #8
Fermelmehue
Drives: 228i xdrive
They're O.Z. Hyper GT HLT from Tire Rack. The tires are humble General G-Max RS summer tires, and they definite ride less harsh than the stock runflats. Their stickiness means I'm noticing more body roll now, so after they wear out I might replace with high performance all seasons. I only got 'em mounted yesterday so I haven't had quite enough time to fully form my opinions about that, but I love those wheels.
GrimJaw103.50
      04-19-2020, 10:03 AM   #9
GrimJaw
GrimJaw's Avatar
104
Drives: 2015 M235i
Yeah those are the exact ones I was going to get (wheels) same size. This is the tire I will prob go with. Unfortunately/fortunately the car came with tire/wheel insurance. So I'm guessing I'm stuck with the fn stock wheels and runflats. Supposedly I can switch to a wheel of the same size but the stocks are 18 7.5 and I want the ozs in the 18 8
      04-19-2020, 02:59 PM   #10
Fermelmehue
Drives: 228i xdrive
You can put the stock tires on those wheels. TireRack recommends that size for the 8" wheel. I just like a meatier look so I went with the 235s.
      04-29-2020, 01:13 PM   #11
GrimJaw
GrimJaw's Avatar
104
Drives: 2015 M235i
How are those wheels during winter/ how are they if they hit potholes strength wise?
      04-29-2020, 07:19 PM   #12
Fasteddy1
Drives: 2017 M240i
I have two sets, one for winter and one for summer.
Winter setup: Alutec Drive 18x8 43mm offset with 235/40/18 Michelin Pilot Alpine PA4
Summer Setup: VMR V804 18 x 8 42mm offset with 245/35/18 Michelin Pilot Supersports.
No other mods, no fitment or rubbing issues at all
Pat
GrimJaw103.50
      05-04-2020, 08:12 AM   #13
Fermelmehue
Drives: 228i xdrive
I only got them last month and they're going to be my summer set, so I can't answer with any certainty, but they'd probably be alright.
Search this Thread:
