11-14-2021, 12:49 PM | #1 |
Rep 4
Reliability
I've found a 2014 m235i with 79,000 miles and a 6-speed transmission. No mods and optioned how I would do it new. If this was my only car would reliability be an issue, what should I look for on service records?
11-14-2021, 01:58 PM | #3 |
Rep 4
okay, I'm fine with typical maintenance and expect things to let go like sensors, just wondering if the car generation has any large quirks or repairs that would be time-consuming and extremely expensive
11-14-2021, 03:40 PM | #4 |
Rep 5,262
probably apart from charge pipe, water pump, overflow coolant take pipe, all the assorted gaskets... oil filter housing, valve cover and oil pan ones...
11-28-2021, 02:37 AM | #5 |
Rep 4
Make sure to have the trans checked out. Had a friend who bought a used 6MT 435i that needed a new trans due to 2nd gear synchros being worn out. I believe it is a common problem with the ZF 6MT transmissions BMW uses.
