11-06-2021, 02:48 PM | #1 |
Rep 27
Best value approach for LSD?
I'm wondering how best to get a LSD for my '16 m235i vert. Sounds like there are better options than the factory product. Not sure which is best path for value and performance. I welcome any helpful advice!
Rowie.
11-06-2021, 02:57 PM | #2 |
Rep 913
Rogue Engineering SSK & transmission mounts, WaveTrac LSD. Ohlins R&T coilovers, Turner monoball thrust arms, F87 LCAs, GC camber plates, Superpro subframe bushings, Megan Racing adj. RCAs, delrin differential bushings. Stoptech BBK 6 piston (f) 4 piston (r). |
11-07-2021, 11:48 AM | #3 | |
Rep 5,369
Like Wolf GTI pointed out, diffsonline.com is great too and they can give you all sorts of options of LSDs plus optional gear ratios. Keep in mind that if you have an automatic, you will likely need to stay with the stock gear ratio or else the car may not shift right, throw codes, or both. In terms of cost, buying the M Performance LSD or something custom from diffsonline.com will be a wash. Most people spend MORE going with something from diffsonline.com. In the end, you'll likely spend $2500-3000 all in and installed, regardless of the LSD you go with. As I've said so many times on this forum, an LSD is a MUST for this car. It transforms it. With an open LSD and extra power, the rear end is a bit of a mess in comparison.
11-08-2021, 04:48 AM | #4 |
Rep 115
Might be worth considering: http://www.teammfactory.com/catalog/.../MF-TRS-05E46A
11-08-2021, 03:22 PM | #5 | |
Rep 5,369
WolfGTI716.00 |
11-08-2021, 06:38 PM | #6 | |
Rep 913
To add to XutvJet's post - you would need to drill out the welded crown gear from the factory diff as it is no longer bolted on, then machine and drill the gear to bolt to the LSD. When you are installing the actually LSD into the differential housing you also to get the pre load correct or it will whine and you will get driveline lash when you hit the gas.
11-08-2021, 08:56 PM | #7 | ||
Rep 27
Rowie.
11-08-2021, 09:29 PM | #8 |
Rep 913
Watch for Black Friday specials - some of the vendors here run specials on diffs.
Frosty779.00 |
