2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack 265 rear
      10-28-2021, 10:42 AM   #1
ChanstonBlake
Drives: 2017 BMW M240i
265 rear
Going to be ordering some Bimmerworld ta5rs in 18x9 et42 soon. I know you can fit 255s square but what about 265s in the rear how close do you guys think it値l be? I知 on BC coils so I知 not too worried about the front. I知 also going to roll the fenders. I知 thinking maybe with a slight pull in the rear the 265s will fit?
      11-03-2021, 08:27 AM   #2
cironephotosucks
cironephotosucks's Avatar
No_Country
Drives: 2015 M235i
I tried a few different things trying to get a 265 upfront and alas no luck, in the rear it痴 doable
      11-19-2021, 05:23 PM   #3
WolfGTI
WolfGTI's Avatar
2002 MINI Cooper S  [0.00]
2015 BMW X1  [0.00]
I run 265s in the rear with 18x9 et 47 no fender work needed. 42 will be tight if you're lowered.
Rogue Engineering SSK & transmission mounts, WaveTrac LSD.
Ohlins R&T coilovers, Turner monoball thrust arms, F87 LCAs, GC camber plates, Superpro subframe bushings, Megan Racing adj. RCAs, delrin differential bushings. Stoptech BBK 6 piston (f) 4 piston (r).
      12-01-2021, 07:22 AM   #4
rtl32
Drives: M235i 6MT
I'm on a conti Extremcontact Sport 265/35/18 on Dinan springs and KW dampers pretty low. 18x9.5xET45 with the slightest amount of superficial immediate sidewall rub from the edge of the fender liner. Like literally just enough to polish the sidewall just inside from the tread thats it. I'm running 1.9 degrees camber in the rear. I have never heard a noise or felt it even doing donuts or with a full set of 4 passengers + luggage.
14' Alpine White M235i 6MT, BM3 Stg2+, VRSF DP-CP-FMIC, Dinan Muffler, GFB DV+, 3.5 bar MAP, Dorch Stg1 HPFP, NGK 97506, BM3 Flexfuel Kit, CDV delete, KW V3, EDC delete, Powerflex Camber LCA bushings, VMR 801 18x8.5/9.5 et45, Conti Extremecontact 235/265
Next step: M2 Competition or Manual Supra MKV build Summer 2022
      12-02-2021, 09:20 AM   #5
ChanstonBlake
Do you think I could fit a 265 in the rear with a 18x9 ET42? It looks like the wheel will be about 3mm further inside according to calculators. I just don't know about tire bulge
      12-29-2021, 05:50 PM   #6
rtl32
Drives: M235i 6MT
That would probably be ideal just watch your inner strut tower and clearance, I know mine is tight as is with 45 but don't remember if it was mm or more. Worst case you can put a 2-3mm spacer in and definitely be clear. Go for it.
      01-03-2022, 07:50 PM   #7
blatif
Drives: BMW M240i
I run a 265/35/18 rear as well on 18x9.5 et45. Lowered on HR springs and running 2.4 deg camber. Very tight fitment and got the slightest fender liner rub passenger side initially on install which has gone away.
      01-06-2022, 11:47 AM   #8
ChanstonBlake
I ended up going with 18x9.5 et 43 so just barely further out than your setup. I think I'm going to pull the fenders slightly and get a little more clearance. I'm assuming your rear control arms are stock?
      01-10-2022, 07:30 PM   #9
blatif
Drives: BMW M240i
Yeah rear control arms are stock. A fender pull is pretty much all you can do since its already rolled. Will be somewhat noticeable though
