2Addicts | BMW 2-Series forum BIMMERPOST Universal Forums General Automotive (non-BMW) Talk + Photos/Videos Remember,slow in - fast out
      10-22-2021, 09:56 PM   #23
E92inNC
E92inNC's Avatar
1710
Drives: E92 335i
I wonder which corner(s) have the highest accident rate
harry.h65.50
      10-22-2021, 10:43 PM   #24
5.M0NSTER
5.M0NSTER's Avatar
Drives: 2018 Camaro SS 1LE
My rating in order:
Brunnchen
Aremberg (if you loose it in Schwedenkreutz you crash at Aremberg)
Adenauer Forest
Pflanzgarten II
Hatzenbach
Nordkurve (now Sabine Schmitz corner)
Tiergarten
2017 BMW M2 German Spec
6MT, Driver's Package
--> SOLD
2018 Camaro SS 1LE. Because race car!
"Redline a day keeps the mechanics away"
harry.h65.50
      10-25-2021, 09:42 AM   #25
M5Rick
General
M5Rick's Avatar
60014
Drives: M5 F10 DCT Gunmetal
Originally Posted by VisualEcho View Post
Oh God, don't go there. More Porsche's have killed people than probably any other make (not sure about the stats there, Ford Mustang? lol).
Visit some of these videos...
https://www.youtube.com/results?sear...h+compilation+
It's fair to say 911's and Mustangs have claimed a lot of inexperienced victims.
      10-25-2021, 09:48 AM   #26
M5Rick
General
M5Rick's Avatar
60014
A lot of the crashes there would be avoided if in the dry slicks would be fitted instead of normal tyres which cannot live with the forces put out at the 'Ring.
      10-25-2021, 10:08 AM   #27
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
There's a turn that new drivers miss. It's a RH uphill turn which starts with a long downhill str8 coming off a LH turn.. The run off is gravel.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      10-25-2021, 10:40 AM   #28
Tambohamilton
Drives: E91 330d
Sounds like brunnchen...
      10-25-2021, 10:47 AM   #29
Tambohamilton
Drives: E91 330d
Yes, accidents would be much less likely if cars had limitless grip...?
5.M0NSTER3353.50
      10-25-2021, 12:21 PM   #30
OkieSnuffBox
Drives: '13 135i
Not really. Inexperienced drivers can just as easily, and actually more easily, overdrive the grip levels on slicks.
200TW tires make more noise as you approach the grip limit and are more forgiving to catch an oversteer/understeer situation than slicks that are more on/off.
The crashes would be avoided by people who don't know what they are doing driving well past their abilities. Some of these people don't even have proper position on the steering wheel with their hands, or distance to the steering wheel, etc.
Most of the people you see smashing up their cars likely don't even understand what the traction circle is or slip angles are in regards to grip level.
5.M0NSTER3353.50
harry.h65.50
BMWILUVU809.00
      10-25-2021, 12:51 PM   #31
M5Rick
General
M5Rick's Avatar
60014
Make no mistake with slicks you'd have faster lap times easy and more control with the suspension firmed up and naturally with someone with an iota of knowing what they are doing.
A lot of those bods that went off the track appeared to have traction switched off, big mistake.
      10-25-2021, 01:18 PM   #32
5.M0NSTER
5.M0NSTER's Avatar
Better tires don't compensate the ability to manage a car at the limits. They shift the problem to a higher speed.
If you can handle over/understeer on street tires, you'll go quicker on slicks. Otherwise the crash just happens at higher speed.
--> SOLD
      10-26-2021, 03:27 AM   #33
eluded
2JZ-GTE
eluded's Avatar
Bulgaria
3032
Drives: 340 6MT, 50e, others
S2k for the win
      10-30-2021, 04:12 PM   #34
Efthreeoh
General
Drives: The E90 + Z4 Coupe & Z3 R'ster
LOL. The cars in the first video seem to crash at not very high speeds. The E30's seem impervious to track conditions.
      10-30-2021, 05:25 PM   #35
freakystyly
Drives: F22 B58 6MT
Looks like a mix of poor tires and poor throttle control with a healthy smattering of overconfidence.
When your tires are screetching like that and the car is going the wrong way, yeah you done gone and screwed up.
M5Rick60013.50
      10-31-2021, 09:34 PM   #36
P1
P1's Avatar
11569
Drives: 2004 3/4 ton Duramax
I always heard that if you're going to crash, crash head on as opposed to trying to avoid it and hitting at a corner. I believe that 5:00 proved that theory.
M5Rick60013.50
      10-31-2021, 10:43 PM   #37
BeEmVe
Drives: '14 X1 x28i M-Sport
Dunning and Kruger would love the Nürburgring.
      11-18-2021, 03:43 AM   #38
M5Rick
General
M5Rick's Avatar
60014
You're correct and that goes on the street too, if someone pulls out on you and you can't brake in time then hit them rather than steering away to get hit from the side and going into others and yes the white M3 had no or little damage hitting armco head on.
      11-18-2021, 08:37 AM   #39
BMWILUVU
Drives: 340ix
Same guys who complain about so and so high performance tires not lasting more than one or two track days and blame it on the rubber.
