10-18-2021, 01:56 AM | #1 |
Rep 4
Bootmod3 OTS N55 question
Hey all,
I've just flashed my M235i with Bootmod3's ACN91 Stage 2 map (being a bit cautious seeing as I only have exhaust mods and no uprated FMIC, with sometimes questionable fuel quality and high altitude). However, I see there are Multimaps. Are these compatible with the M235i, or are they M2 specific, seeing as they state that the 4th map is M2 stock. |
10-19-2021, 05:08 PM | #2 |
Rep 44
This post should perhaps be moved to the N55 section?
Yes, the multimaps are compatible with M235i. I’ve been running the stage 2 multimap for the last 3 months. Nice to be able to switch between ACN, 91 or 93 maps depending on the fuel quality available without reflashing (don’t forget to log). The 4th “M2” map is supposedly similar to the stock OG M2 map and has a more flat torque curve without the initial shove that the other OTS maps has. I have tried it a couple of times and it felt nice, but I noticed some strange behavior and need to properly logs before I conclude with anything. |
