2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions What can I easily DIY???
      07-28-2021, 01:22 PM   #1
BimmerDubs
Drives: M240I
I have a 2017 F23 M240i and am planning on doing my first oil and filter change this weekend. I live in a small town with no BMW dealership (closest one is 2 hours away) and no real BMW/foreign car “mechanic.” For my other cars, I take them to a 10 minute oil change place (I don’t want them touching my M240i).
I am a total novice to all of this!
Now that I have a floor jack and jack stands and access to under the car, what other things (general routine maintenance or minor performance mods) can I do by myself that are relatively easy? Any other DIY things in general? I have already changed my engine and cabin filters and have also done some “idiot” coding (i.e. BimmerCode!).
Thanks for any suggestions!
      07-28-2021, 01:31 PM   #2
KennyFSU
KennyFSU's Avatar
1103
Drives: Lexus RC F
Oil changes are extremely easy on these cars, check out YT for step by step directions.
Might I suggest some Rhino ramps instead of the jack/stand combo? I find this route much faster and do oil changes in my outdoor parking spot with ease. I use OEM oil and filters or some use FCP Euro.
Intakes are easy and downpipes can be done in an hour or two.
Estoril Blue E36M3
Mineral Grey M235ix/12.02 @ 115
Ultra White Lexus RC F
      07-29-2021, 09:07 PM   #3
BimmerDubs
Drives: M240I
Thanks for the suggestions....need to look into the intake and downpipes!
      07-31-2021, 11:50 AM   #4
da jemster
da jemster's Avatar
78
Drives: E46 M3,E93 M3,F22 M235i,i1 i3
Originally Posted by BimmerDubs View Post
I have a 2017 F23 M240i and am planning on doing my first oil and filter change this weekend......
I am a total novice to all of this!....
DO NOT OVERTIGHTEN THE DRAIN PLUG! That was my rookie mistake eons ago and I stripped a plug in my VW Bug, thinking "is it tight enough so that it won't leak". Get yourself a good torque wrench.
'04 E46, '08 E93, '16 F22 M235i, '17 i01 i3
      10-28-2021, 08:21 AM   #5
Fergusonic
Drives: 2020 M240iX
Newby question: M240i: I see many use rhino ramps to be able to access the engine oil drain plug. So now that the car is on Ramps and not level; does this mean that all of the oil will not drain?
After further research I found that a small amount of old oil remains; but should not be enough to matter....... supposedly
      10-29-2021, 08:10 AM   #6
MarcoZandrini
Drives: 2018 M240i
THIS! 18ft-lbs and no more! What, you don't have a torque wrench? Buy one!
      10-29-2021, 09:49 AM   #7
Jcoop901
Southern Fried
Jcoop901's Avatar
Drives: BMW M240i
2017 BMW M240i  [9.00]
So far I've done the following in my driveway with a floor jack and jack stands. I also bought Rhino ramps and they work great however, you need to add a small 2x4 in front of the ramp to keep the front splitter from dragging.
1. oil change
2. spark plugs
3. brakes
4. catted downpipe
5. intake
6. complete stereo install including trunk sub-box and amp
7. Not BMW-related, but I put a 3" lift on my Jeep Wrangler by myself in the driveway.
      10-29-2021, 10:17 AM   #8
freakystyly
Drives: F22 B58 6MT
If you're comfortable working on the car or have access to youtube, I didn't see mentioned yet:
Brakes
Suspension
Pretty much all fluids (some may require pumping)
Search this Thread:
