2Addicts | BMW 2-Series forum Classifieds Commercial Classifieds Engine / Drivetrain / Exhaust / Bolt-ons AutoTalent | Dinan exhaust+roll bar+spring+control arm+tuner for Bmw M240i 2017-2018
      09-25-2019, 01:49 PM   #1
AutoTalent
AutoTalent's Avatar
2312
Drives: e92 M3 6mt | e60 M5 6mt
Dinan Free Flow Exhaust
To order exhaust with black tips please visit our website by clicking HERE
To order exhaust with polished tips please visit our website by clicking HERE
The system is built to exacting specifications to ensure perfect fit using the factory hangers. It is made from 100% 16 gauge 304 stainless steel and will resist corrosion for years to come. The design features twin 89mm (3.5") ceramic black exhaust tips for a tasteful, high-performance look.
Features
+ Uses the factory brackets and hangers for a factory-like fitment.
+ Helmholtz chamber to reduce drone.
+ Enjoyably louder, sportier Sound
+ 100% 304 stainless steel construction
+ Twin 89mm (3.5") laser engraved ceramic black exhaust tips
+ 6 HP @ 6600 RPM, 5 FT-LB
+ Factory computer controlled exhaust valve is eliminated
Dinan High Flow Mid-pipe
To order for Rwd please visit our website by clicking HERE
The Dinan High Flow Mid-pipe for the F22 M240i allows for an aggressive tone to be achieved out of the stock system. Coupled with the associated Dinan exhaust the sound is further perfected into an aggressive growl that is hard to ignore. This full mid-section removes the factory center section, including both resonators, and replaces it with straight through 3.25" T304 stainless steel tubing for better flow, and sound while also reducing the weight by 3 pounds.
Dinan Adjustable Anti-roll Bar Set
To order anti roll bar set for Rwd please visit our website by clicking HERE
To order anti roll bar set for xdrive please visit our website by clicking HERE
Dinan tuned anti-roll bar is built and tuned specifically for each BMW chassis. Lowering the amount of body roll keeps your BMW more level than stock (while still allowing just enough body roll) to improve mechanical grip. This improvement gives the driver a much more planted and confident feeling in every corner.
Features
+ Less Body Roll
+ More Mechanical Grip
+ More Stable At Limit
+ Large 28mm size
+ Large 19mm size
Lower Control Arm Monoball Kit
To order please visit our website by clicking HERE
The quietest bearings on the market are virtually noise free so you can live with them everyday. These are the only bearings on the market that are sealed using a rubber boot to keep out dirt and road grime stopping them from wearing out prematurely. The Dinan Monoball Kit provides responsiveness you can feel by replacing the rubber bushings in the thrust arms with precision ball joints and machined aluminum housings. Improves responsiveness by eliminating the deflection inherent in the stock rubber bushings while also reducing brake shimmy.
Features
+ Improved Steering Responsiveness
+ Reduces Brake Shimmy
+ Nylon-lined Bearings for Quiet Operation
+ Machined Aluminum Housings
+ Sealed Bearings
Dinan Camber Plates
The positive adjustment range on the camber plates is unique to Dinan and allows the end user, if desired, to retain OEM camber settings on a lowered car or to combat excessive negative camber brought upon by springs that aggressively lower the car. Not only do the Dinan camber plates provide a wide range of adjustment but they also have ride quality in mind like all of Dinan's suspension components and are designed to properly retain the bumpstop so that it compresses as designed from the factory. Dinan camber plates are also built to take a beating and are the only ones that utilize a steel alloy mount plate that will resist deforming from pot holes on the street or curb hopping at the track.
Features
+ 43mm of total camber adjustment (30 negative, 13 positive from OEM). This translates to 2.5 degrees of negative camber and just over a degree of positive camber being possible.
+ Decreased understeer
+ Decreases outside edge tire wear
+ Steel alloy mount plate and not aluminum
+ Fits with factory strut tower weather seal
Dinan Performance Spring Set
To order spring set for Rwd please visit our website by clicking HERE
To order spring set for xdrive please visit our website by clicking HERE
Dinan's Performance Spring set for the F22 M235i/M240i provides greater control over body roll by virtue of carefully calibrated spring rates. Additionally, Dinan lowers the M235i/M240i by a 1/2" in the front and 5/8" in the rear for improved suspension geometry and an even more aggressive stance. The Dinan springs are CNC wound with high tensile chrome silicon wire and shot peened for stress relief to last the life of the car. The Dinan performance springs provide a noticeable improvement in grip, for high speed driving situations that will inspire confidence in your car's capabilities. The reduced body roll makes the steering more responsive to driver input and will be noticed at low speeds up to the top speed of the vehicle.
Featureas
+ 10% increase in spring stiffness in front and 27% increase in the rear
+ Lowers the vehicle 1/2" in the front and a full inch in the rear
Dinan High-Performance Tuner
To order performance tuner please visit our website by clicking HERE
To order sport performance tuner please visit our website by clicking HERE
The DINANTRONICS Performance Tuner is a highly engineered piece of computer hardware and software that enhances engine performance to levels the stock programming is not allowed to venture into. It does this without negatively affecting your new car warranty coverage and without affecting long term reliability or the functionality of on-board diagnostic systems. It is also the only tuning device designed to be emissions legal in all 50 states. These items are unique to Dinan and together they embody the apex of performance engineering in a powerful, reliable, and warrantied package.
The Dinan Difference is possible by employing a full staff of talented engineers that are well rounded in many facets of automotive engineering and backed by a wealth of hands on knowledge. Stemming from diverse backgrounds not only on racing teams but on standard factory production line vehicles we have seen it all. Manipulating these signals with an adept hand all the while keeping an engine running at its best and with the most reliable power is what Dinan is all about.
How to Place Your Order:
Phone Domestic: (855) 973-2757 X 104
Phone International: (310) 231-7800 X 104
E-mail:
online@autotalent.com
Website:
www.AutoTalent.com
Payment:
Installations:
Feel free to visit us at our facility in Los Angeles, CA.
We install everything we sell.
19143 S. Hamilton Ave
Gardena, CA 90248
Shipping:
All orders are shipped via FedEx, UPS, USPS and Pilot.
International, Hawaii and Alaska customers: Please contact us for the best quote possible.
Hours of Operation:
Monday through Friday: 10AM-7PM Pacific Time
Saturday: By appointment only
      11-16-2020, 07:34 PM   #2
AutoTalent
AutoTalent's Avatar
2312
Visit our website by clicking HERE. Please feel free to reach out with any questions or inquiries!
      12-21-2020, 08:05 PM   #3
AutoTalent
AutoTalent's Avatar
2312
      01-20-2021, 07:24 PM   #4
AutoTalent
AutoTalent's Avatar
2312
      02-09-2021, 06:03 PM   #5
AutoTalent
AutoTalent's Avatar
2312
      02-23-2021, 09:08 PM   #6
AutoTalent
AutoTalent's Avatar
2312
      03-04-2021, 06:43 PM   #7
AutoTalent
AutoTalent's Avatar
2312
