04-22-2014, 04:23 PM | #24 |
Rep 1,040
Just finish installing my new gloss black grills on the car tonight. Easier to do than I was expecting. You can pull the bumper cover enough away to release the top 3 and two sides pretty easy; even with my big ass forearms . The key is push all five tabs down before you start pulling on the front of the grill. This will get them recessed enough so once you have the top 3 and 2 side pressed in you can pull with just a little pressure to get the top to pop outward. Once you have the top popped you reach down to the bottom two and push upward to release the complete grill. The second grill can be reached from the opening from the first removed grill. Big difference in the front appearance. The wife said it looks tougher now.
04-23-2014, 06:27 PM | #26 |
Rep 1,040
04-25-2014, 12:19 AM | #27 |
Rep 61
I did mine tonight, and just as a reference, here is how much of a gap you have to work with. Having smaller hands/arms is definitely a plus here, its not too much space haha
current:
2014 BMW M235i Black on Black 2012 BMW F800R sold: 2004 Dodge SRT-4, 415whp 416wtq |
04-25-2014, 07:20 PM | #28 |
Rep 1,040
I pulled my out farther than that. The bumper cover will flex a good bit. Once I had the right amount of opening I had my wife hold it for me while I released the tabs.
On second look, did you remove the rubber hood gasket, remove the torx screws and pull the bumper cover out from under the metal tabs and plastic ends near the headlights? The photo looks like you remove the 4 Torx bolts near the radiator instead. Last edited by Delnari; 04-25-2014 at 07:25 PM.. |
04-25-2014, 08:03 PM | #29 |
***** noob
1370
Rep 10,479
Wish you had taken pics for us so we dont rip the bumper apart
2006 325xi (Sold)
05-05-2014, 06:47 AM | #40 |
Rep 42
05-05-2014, 10:44 AM | #41 |
Rep 1,040
Never seen a CEL with this intake or any other I have installed that retains the MAF sensor. From inside the car I hear no difference, but I haven't had it rev'd up while outside the car either . The only reason I have an intake is because I have the JB4 Map 1 tune running with it. Really don't believe just an intake alone without a tune does much good; have even read that some CAI's can reduce HP/Torque in different parts of the rev range. Boosted cars like ours can take advantage of the increased airflow if they are tuned for it. My previous WRX with CAI, DP, Pro-Tune, and muffler gained 58 HP and 66 ft. lbs of torque over stock which cost me $2000 in parts plus time and labor. Compared to the $800 I have spent on the M235i to gain +28 HP and +35 ft. lbs. of torque.
05-05-2014, 11:05 AM | #42 |
Rep 42
Thanks, if you running JB4 then it will cancel any CEL, am not really looking
to increase power at the moment but would love a bit more sound but getting the impression that without removing a lot of sound deadening/insulation then not much I do is going to help, from the inside anyway. |
05-05-2014, 11:03 PM | #43 | |
Rep 1,805
Looks good man! Can you please take a picture from about 20 feet away? It's hard to gauge how they look from so close. Thanks
2014 F30 335i / 2014 F31 328d / 2014 F22 m235i
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is 2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3 2017 Alpina B6 22 Ram Trx / 22 M5 CS |
