12-13-2018, 04:03 PM | #1 |
Rep 20
m235i acceleration over 60+ mph weird characteristics
When I go to accelerate onto the on ramp the car seems to dart from left to right and feels highly unstable. Have owned many bmws and never felt this before. It seems like it has been like this since Ive owned my m235i. At first i thought it was just normal because the tires are only 255 wide on 18's on square setup but now that I have a stage 2 tune it seems like it has got worse.
Is the suspension on these cars far inferior to the e46 m3s and e36 m3s?? is it the lack of a lsd? Also my father has driven the car and complains that the steering rack is way to quick almost like it takes way too much input to keep strait line driving. |
12-13-2018, 04:24 PM | #2 | |
Rep 823
12-13-2018, 04:28 PM | #3 |
Rep 20
I just bought two new Michelin as3s to replace the fronts but instead i rotated the rears to up front and put the new as3s in the rear. and yes the right front has a buldge but why would that affect it? Because of balance?
12-13-2018, 06:03 PM | #4 |
3626
Rep 3,592
Mis-matched tyres will also cause this sort of instability. If the two front tyres aren't also the same as the rear (i.e. Michelin AS3s), then that could be the problem.
If you bought the car with Michelin AS3s all around, then they are not factory original and may have been installed due to a tyre failure caused by a pot hole or other impact, which would also place suspicion on the alignment of the car, which could also be the cause of your instability. I find our F22 M240i is more stable from a tramlining perspective than the E46 323Ci we owned in the past. |
12-13-2018, 06:11 PM | #5 |
Rep 5,577
Sidewall consistency probably induces pull under acceleration.
12-13-2018, 06:17 PM | #6 |
Rep 823
There's your answer. It's definitely the bulge in the tire. As mentioned above, the same thing happened to me and the first thing I did was inspect my tires. Lo and behold, there was a bulge in the RFT. Replaced all 4 with non-RFT's and haven't looked back since.
12-13-2018, 07:32 PM | #7 |
Rep 20
The fronts are Michelin sport cups and the rears are Michelin as3 I would have got the sport cup but they don't make them anymore. Hopefully they will replace the tire under warranty due to defect. This death wobble is not safe.
12-13-2018, 09:54 PM | #8 |
3626
Rep 3,592
Sport Cups or Pilot Sports (which are a standard option on the 2-series)? If they are Sport Cups, you have a recipe for disaster if you are mixing them with AS3 all season tyres, as their grip relative to temperature and heat in the tyres is quite different. If they are Pilot Sport tyres, they still shouldn’t be mixed with all season tyres and handling inconsistencies should be expected if they are mixed.
12-13-2018, 11:44 PM | #9 |
Rep 373
how did you rotate the rims? the rears are wider then the fronts 7.5j front 8j rear
'14 F20 M135i EWG FBO:// INJEN INTAKE // PURE INLET// TURBOSMART BOV DUAL PORT // //CSF INTERCOOLER // ER CP // SNOW S2.5 METH KIT // B58TU HPFP // NGK 97506 // ER DP // TMSS MID PIPE //MPE // MPBBK // UR STRUT BRACE // BM3 CUSTOM JORDAN E85 TUNE // XHP STAGE 3 // |
12-14-2018, 07:52 PM | #11 |
3626
Rep 3,592
You shouldn't mix tyre types from a stability perspective. Run flat max performance summer tyres (Pilot Sport ZP) will not work very well with ultra high performance all-season conventional tyres (Pilot Sport A/S 3+). You need four tyres of the same performance category to get the car to handle well under hard use.
01-01-2019, 02:01 PM | #12 | |
Rep 52
01-31-2019, 08:47 PM | #15 |
Rep 211
What I suspect is rear subframe bushings. They are extraordinarily soft on these cars. I have a video where I'm able to move entire subframe up and down with minimal force.
I installed poly bushing inserts before storing the car for winter. I think it felt a lot better, but I was not able to put many miles so feedback is limited. Hope I can update in few months. |
