10-12-2018, 01:28 AM | #1 |
Rep 233
Drives: '18 M2 LCI
I removed the negative side of my battery to do some work on the steering wheel and I after I reconnected negative wire, my car starting throwing different codes. The first was resetting the date and time and the second was PDC malfunction and parking sensor errors. The rear view camera is working, but the front and rear sensors aren't. Anyone know what to do?
EDIT: Turned on the car this morning and the code was still there. Drove down the street and the code cleared itself and everything is working again.
'18 M2 LCI 6spd
10-20-2018, 07:26 PM | #2 | |
Rep 277
Drives: 2018 230i MSport
If you disconnect and see chassis stabilization that will also clear after a short drive down the street. Power steering fault however will not clear. You will need to unplug the battery and wait a while and try again... ask me how I know it doesn't clear after driving a bit without power steering... Glad you got it worked out. I was freaking out I messed up my car first time it happened to me |
trilax5991.50 |
