06-04-2018, 10:32 AM | #23 |
Rep 2,873
My local place recc'd ATE 200 - very close to the Motul specs IIRC. Apparently it comes in blue or light amber, so you can tell you've flushed it all out (but they may be d/c'ing the blue because of some safety concerns or s/t?). I was also impressed that the factory fluid is only a few tics down from these in terms of wet/dry boil-points (inferior, but not a huge drop off if you decide to stick w/ factory).
06-04-2018, 03:38 PM | #24 |
Rep 525
Looks like there may have been a change made to the RBF660. I recall they used to have slightly lower wet boiling point compared to RBF600 but with a higher dry boiling point. You also needed to flush 660s much more frequently than the 600s because it was more hygroscopic. I'm thinking they just revised the numbers to show 660s as having better numbers all around because most people simply opted for the 600s due to the cost difference and very little gains in performance.
Anyway, ATE Super Blue and ATE Typ 200 are also very good DOT4 fluids that are much cheaper than the Motul fluids. It doesn't have as high of boiling points but you can just flush twice as often as long as your brakes had sufficient cooling (or didn't get too hot) and doesn't require higher temp fluids. That said, nobody's been able to get Super Blue for several years in the US as it was made illegal (possibly also discontinued elsewhere now), due to stupid people confusing the blue brake fluid for something else. BTW, the very best brake fluid, AFAIK, is the Castrol SRF. Too bad they're just exorbitantly expensive. |
06-05-2018, 07:43 PM | #26 | |
Rep 2,601
My car is primarily a daily driver so I think I will leave the safeties on. |
06-11-2018, 05:57 AM | #27 |
Rep 31
Post-Track Impressions
I just got back from the track and I'm very pleased with these changes. The handling is very neutral now with the square tire setup. The pads and fluid both performed very well on the track. I didn't get any fade or softness in the pedal. We even got an extended session late in the day and the only reason I had to come in was because I was running out of fuel!
06-12-2018, 11:18 AM | #30 |
Rep 2,700
I read that the Gulf R1000 is the same formulation, I flushed mine last saturday and went to a small very technical track on sunday and even with stock pads never ran out of brakes, I was pleasently surprised. And I'm on RE-71R so they did taste some heat.
Fun/HPDE: 2023 M3 6MT Individual Malachite
Past:2023 M4 CSL, 2022 M4C Vert, 2020 M340i, 2018 M2, 2015 M235i, 2008 135i 550whp Daily: 2023 X5 45e Daily/Family: 2021 Atlas Cross Sport 3.6 |
Dylan861330.00 |
06-13-2018, 01:21 PM | #32 | |
Rep 3,496
