12-20-2017, 06:44 PM | #1 |
Rep 4,551
Drives: 2015 328d xDrive
Rear fog lights on without the headlamps?
Recently coded in my rear fog lamps and did the button mod:
http://www.2addicts.com/forums/attac...4&d=1421099515 Anyone know if it's possible to code the rear fogs so they can be turned on by themselves, without the headlights turning on as well? Last edited by AndrewC1989; 12-21-2017 at 02:59 PM.. |
12-21-2017, 02:01 PM | #3 |
Rep 120
Drives: 2018 BMW M240i
I’m pretty sure you can’t, and why would you want to do this anyway? If there aren’t low-visibility conditions, where you’d want your headlights on in the first place, the rear fog lights are annoying to drivers behind you.
12-21-2017, 02:04 PM | #4 |
Rep 4,551
that's the idea. i use it as a "stop tailgating me" button. (i don't drive around with them on normally).
i was just curious if it was possible to turn them on without the headlights coming on. it turns out you can't. no big deal. Last edited by AndrewC1989; 12-21-2017 at 03:01 PM.. |
delvec0389.50 |
09-26-2018, 06:03 PM | #5 | |
Rep 168
Drives: X3 X28i ; M235i xdrive Convert
Please let me know Mike michele1070@gmail.com cell 2013762877 |
09-26-2018, 06:06 PM | #6 | |
Rep 4,551
10-05-2018, 10:19 AM | #7 |
MBurg
63
Rep 236
I have a '19 230i
Two questions: 1. Does anyone have a more detailed guide about how to remove the AC vent/light switch? 2. Once the switch is modified, is it still necessary to code the switch to turn on the rear fog? If so, is there an easy way to do this with Bimmercode 'app'? (I guess 3 questions). Thanks |
10-05-2018, 10:29 AM | #8 | |
Rep 4,551
https://f87.bimmerpost.com/forums/sh....php?t=1450178
10-05-2018, 11:06 AM | #9 | |
MBurg
63
Rep 236
Thanks for this link.
Is there anything more specific about removal of AC vent to get at the light switch? Quote:
10-05-2018, 11:07 AM | #10 |
Rep 4,551
You just pry it out with a trim tool. It's not held in place by anything.
10-08-2018, 09:59 AM | #12 |
MBurg
63
Rep 236
10-08-2018, 10:49 AM | #13 |
Rep 4,551
You don't even need to pry the switch out if you aren't replacing the entire thing. If you're just doing the button shaving method you can literally just pry the rear fog button out by itself.
