01-20-2020, 07:27 PM | #45 | |
Rep 4,551
Drives: 2015 328d xDrive
https://f30.bimmerpost.com/forums/sh....php?t=1555872 It's been a year and about 10-15k miles later and we had some light snow recently (2-3 inches) but there was a lot much slush and wet snow (unlike last years storm). I had a lot more wheel spin/dsc intervention off of stoplights and stop signs but I wasn't being super-light or modular on the throttle and diesels are known to be torquey so I'm not sure if I can attribute that to driver error or tire performance/wear. Either way, I don't find these tires to be loud as others have complained (maybe I'm deaf), and I find the winter performance to be adequate for people living in places where it only snows a handful of times a year. I'm tempted to try the DWS06's next because I've heard the snow performance is slightly better, but with xDrive and only a few snow days a year I'm not sure if it would really be worthwhile. ~360 days of the year we're snow-free and I think I value the warm, wet, and dry performance over the snow performance. As long as you drive slow these will get you where you need to go safely. |
01-20-2020, 10:08 PM | #46 |
Rep 45
For everyone saying the AS3+ is bad in snow, is it actually worse than the OEM RFTs?
I'm still on my stock RFTs, and have been considering what to replace once I wear them out. AS3+ seemed top of list for me. I'm in Boston area, but can easily avoid driving in any real amount of snow. Can't avoid driving in cold though. I have no complaints about the performance of the OEM RFTs though, so if they are just better, then hurray. |
01-22-2020, 09:18 PM | #47 |
Rep 611
I have had DWS06 and AS/3+ on several cars and the handling of the AS/3+ is outstanding in the dry and warm--very noticeable improvement in turn in, feel and limit of traction in curves. I don't find it significantly louder than the DWS in the sizes I have experienced. Living in the mid south we often go through winters with no snow these days and I am unwilling to trade the excellent performance 98% of the time for slightly better snow performance < 2% of the time.
I have also tried the Potenza 980 and it was slightly below the michelin in handling but had ungodly wet traction that lasted the life of the tire. However the hydroplane resistance was much worse than the AS3 or the DWS. It didn't snow the year I had those on. If you are happy with the DWS you should stick with them--they were just too soft for me. |
01-27-2020, 08:48 AM | #48 |
Rep 2,214
Since the AS3+ outperforms many competitors pure summer performance tires, I'd be concerned about how the compound would fair in colder temps. I feel they're similar in compound to a PSS but a bit harder, and PSS's are noticeably poor in colder temps.
I have Xi3's and they're great, but obviously a dedicated tire..
01-27-2020, 12:13 PM | #49 | |
Rep 5,372
I had a set of Bridgestone 960 ultra high performance all season tires. They were killer in the dry, but we're frightening in temps below 30 and in the snow/slush/wet. I traded them out for DWS after one winter season and lost some dry warm weather performance, but holy hell were they so much better in the winter. Apples to oranges. I know the AS3+ has been revamped with an improved compound, but I have hard time believing that they'll offer the same level of winter performance as the DWS which as a ton more sipping and a portion of its tread design that is similar to a winter tire.
Dylan861330.00 |
01-28-2020, 09:32 AM | #50 | |
Rep 2,214
Plus, its been known for a while now that if you actually make the upfront investment in two proper sets of tires (1 summer/AS and 1 winter set) you'll actually save more in the long run due to better tire wear and compounds for the temperatures they're being used in. If you're in one of those areas like coastal NW where it might snow a handful of times per year, than I guess it's something you'd have to decide on, but understand that sometimes it does not make sense to have winters.
01-28-2020, 12:38 PM | #51 | |
Rep 5,372
In Kansas City, we see around 18 to 30 inches of snow every year spread out over 8 to 12 snow events. Rarely do the events exceed 3 inches. Also, rarely do temps drop below 20 degrees extended periods. Daily temps are typically in upper 20s to upper 40s between December and late February. I think the Kansas City winter is comparable to a majority of the cities in the US, especially near the same latitude. I've got Pilot Alpin PA4s (3rd season) and I think they're overkill for Kansas City. Everyone swore I needed winter tires for my BMW even though I had gotten around fine on all season tires in 30 years of driving in Kansas City. Hell, the cops in their RWD Caprice Classics, Crown Vics, and currently their Chargers don't run winter tires and it's fairly hilly in KC. I've found that the PA4s wear out too fast (might get 12K miles out of them) and they handle and brake like a wet pork chop in temps above 40 degrees. They're hilariously terrible in 50+ degree temps. In the snow, they're pretty good, but it's so rare that I really need to drive on snow packed roads. Once these tires are done, I'm going with DWS for my winter tires.
01-28-2020, 03:01 PM | #52 | |
Rep 3,497
I too have a choice as to whether to drive my M240 when its snowing or especially cold out. I don't drive when it snowing or the streets are wet and only drive when it's cold to take the car out for its once-a-month or so two-hour warmup/workout. I think the right A/S tire will work just fine. I've already got A/S 3+s for the shoulder seasons and plan to put 225/45-17 Vredestein Quatrac Pros on my 17" winter wheels later this year. The Quatracs have the snowflake symbol and will be more than adequate for my winter use. They'll do double-duty during extended touring excursions in the warmer months.
01-28-2020, 03:48 PM | #53 | |
Rep 170
The AS3+ are great tires but yeah when it gets sub freezing they are hard and get slicker. Why put my poor M240i through those nasty days anyways? |
01-28-2020, 06:27 PM | #55 | |
Rep 3,497
Yes, we truly are not in Kansas anymore, are we.
01-29-2020, 08:47 AM | #56 |
Rep 170
It's a super great tire for grip in all conditions. I haven't had it in any snow that matters (since we haven't gotten any snow that matters). I will say it seems very soft sides but the yaris has super tall sidewalls. If I was putting something on my M240 it would probably be dedicated snows instead of something like this though. As much as I like the Quatracs I'm pretty sure our cars would overwhelm them easily while being extra squiggly in turns.
dradernh4413.00 |
01-29-2020, 04:02 PM | #57 | |
Rep 2,214
DistantTea101.00 |
01-31-2020, 10:31 AM | #58 |
Rep 242
I know this topic is for the tire thread, but when I was doing my research the Michelin's were highly (highly) reviewed in all non extreme weather temps in dry conditions. People were saying it's basically the 'best' with the only knock being a firm ride and noise depending on car (the way it sounds can either be ignored or not depending on your vehicle).
Anytime it got wet or slushy though it quickly fell behind many others. The Avid Ascend GT for example was better, the General GMax AS, and of course the DWS. It depended on the vehicle/tire size as well. Personally I avoided the Michelin's because they were always over double the price of the competition and frankly weren't that much better (better yes but not double better). They aren't giving any more value. I first narrowed my search to summer only v all season, and the climate I live in does nothing for all seasons. They are summer year round as we never see below 40. But we do see wet ALL THE TIME and that was paramount. I would have gone with the Ascend GT but they were new at the time so no discount and General was pushing the GMax RS. I went with the latter and they are stellar. The most grip I've ever had. Ride is excellent. Cost was less than $100 per. (with free install due to the discount). In hindsight I probably would have gone with the Bridgestone's because while, at a few more dollars per, they may not have as much absolute grip, and be a little less 'direct' in the wheel, that's not really a 'thing' with a daily, and they are substantially quieter than any summer tire which has become the most important criteria for me. They they do wonderfully in the wet is a benefit. Seth |
