2Addicts | BMW 2-Series forum Technical Topics Cosmetic and Lighting Modifications Broken splitter attached part
      02-28-2018, 01:33 PM   #23
Chris_B
Chris_B's Avatar
Drives: Melbourne Red 2016 M235i
2010 BMW 128i  [0.00]
IIRC I had a dealership replace this part for a few hundred bucks.
Took a couple days.
BMW of Vista in California did the repair for me when I hit a 4" metal plate lol
Past: 2008 BSM BMW 128i 6sp w/ EU spec interior.
Past: 2010 BSM BMW 128i 6sp +Msport
2016 MR BMW M235i
Instagram @project_kristi
      02-28-2018, 01:48 PM   #24
//M235ixD
//M235ixD's Avatar
Drives: 2015 //M235i xDrive
Nice! and that sounds cheap. I picked up that part from ebay for around $100 I think. it is painful to get off the ferry ramp here in Seattle with the lip being so low especially around low tide. i am sure i will have to replace mine at some point so i am holding on to it.
Took a couple days.
      01-13-2019, 11:40 PM   #25
mikeyymonster
mikeyymonster's Avatar
Drives: 2021 M2C
Well, after a year, my time has come and my first splitter has ripped off, taking this piece with it. It doesn't look like there was any conclusive info on this thread on whether or not replacing that whole piece will work?
2021 M2C
2014 M235i
Instagram: @mikeyymonster
      01-14-2019, 12:22 AM   #26
Poochie
Luxury at the redline :)
Poochie's Avatar
Drives: 2016 M2
Once you take the bumper off, the bolts and attachment points will be clearly exposed.
Unbolt what's left of the old, broken attachment and bolt on the new one. You need to replace this part, as it attaches to the splitter.
Also note that mounting points for my bumper was also ripped off, so I improvised by using metal washers, hot-glueing them on to recreate the damage tabs.
If had to do it over again, I would probably pass on the new splitter to avoid this nonsense. But it does look pretty sweet but too high maintenance.
Good luck.
      01-14-2019, 12:28 AM   #27
mikeyymonster
Drives: 2021 M2C
Unbolt what's left of the old, broken attachment and bolt on the new one. You need to replace this part, as it attaches over the splitter.
Good luck.
Thanks man, I'm thinking of skipping the splitter as well. So we aren't able to replace the piece without removing the entire front bumper? Or is that more of a convenience?
2021 M2C
2014 M235i
      01-14-2019, 12:41 AM   #28
Poochie
Poochie's Avatar
Drives: 2016 M2
Good luck.
Unfortunately, you have to remove the bumper for the attachment bolts to be accessible. There is no way around that, as the bumper completely covers them.
I guess that's why I'm reading that the labor is close to $1,000 to R&R this piece. Sounds about right for dealer rates..
Just as an added F-U, when I attempted to remove the headlight washer nozzle on the bumper, the end broke off clean, without much force I might add, just the strength of my finger nail. It's very fragile, be careful.
I priced a new washer and it was close to $100, so I just capped them off and decoded the headlight washer feature. I didn't really care for them but I would of liked to keep them functioning, as intended.
      01-14-2019, 12:46 AM   #29
mikeyymonster
Drives: 2021 M2C
My goodness... thanks!
2021 M2C
2014 M235i
