2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack can use rear 255/35 R19 tires?
      10-02-2019, 05:25 AM   #1
KAY-OS
KAY-OS's Avatar
124
Drives: BMW m235i F22
I am currently on Rear 19x9.5J ET45 rims with Advan AD08R 255/30. Unfortunately, I blew a rear tire and shops here don't have AD08R stock at the moment. I wish to use similar level of tire but 255/30 size isn't that common. So, I plan on using RE71R 255/35 R19. Is it doable? Anyone here using 255/35 R19 tires? Any issues? I know it's not recommended, side wall is too thick and it will affect speedometer readings, but there isn't much choice with 255/30.
Thanks for your help.
2014 BMW M235i auto. JB4 & EWG connector + BMS BEF (EWG Race 10 map) + BMS WMI kit (dual BM5 nozzles, 80% meth mix, Boost additive 50, Scaling 60, min flow boost 6.5psi), 98 RON/93 oct pump gas, intake, ER CP, Forge BOV, Wagner Evo II competition intercooler, ER kitty-less DP, eisenmann exhaust, quaife LSD
      10-02-2019, 06:03 PM   #2
VMRWheels
General
VMRWheels's Avatar
2038
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
I wouldn't recommend it. Those are going to be significantly taller than the 255/30/19 and will probably rub constantly. It would be much more headache than it's worth. You might be better off trying to stuff a 265/30/19 back there and add some negative camber, if possible.
      10-03-2019, 10:07 AM   #3
KAY-OS
KAY-OS's Avatar
124
Thanks for your reply. I have KW coilovers, so if I raise the rear a bit, should that help? Also, I just found out a dude I know have installed 255/35 R19 at the rear with no rubbing. Would like to know if others have issues with this tire size. Thanks.
      10-04-2019, 01:00 PM   #4
eddielyk
Drives: M240i
Summer tires set up
Just picked up 2018 M240i xDrive, square set up came with the car.
I am planning to install Eibach springs and staggered set up,
Option 1 : front 235/35R18 and rear 255/30R18
Option 2 : front 235/40R18 and rear 255/35R18
Do I need roll my fender with either above set up, and shouldn't need extra spacer?
What's the offset I can use on concave wheels to make it look good?
Thank you for your opinion and suggestion.
