09-30-2019, 12:12 PM | #1 |
Rep 115
Hit road debris - broke oil cooler
Hit a semi truck tire retread on my drive to work last week. Cracked the front bumper, broke the oil cooler, bent a wheel, lost a tire, smashed the fender, flung off the rocker, and did a number on the underbody trays.
Took a few miles of driving for the low oil pressure light to come on, and another mile of driving once the oil pressure light came on before I found a SAFE place to turn off. Car was still running fine when I turned it off. No visible flakes in the oil filter with a visual check. What are my steps to ensure the engine is OK after the fix? Can the dealer do an analysis? If the engine is damaged would they total the car?
2014 M235i
10-04-2019, 01:36 PM | #2 |
Rep 5,369
Driving as long as you did with oil leaking out and the motor loosing oil pressure is not good. Ideally, you should have pulled over immediately and turned the engine off to assess damage. Any type of large debris hit on a car warrants this.
Yes, collect an oil sample now, then do an oil change, and get the car fixed. You should then do another oil sample in a month/1,000 miles and see what those numbers are. If the metals numbers look alright, then the motor should be ok. You should also apprise your insurance that you're doing this to confirm there's no internal motor damage, specifically bearing wear due to low oil. Elevated lead and copper will be indications of bearing damage.
10-04-2019, 03:07 PM | #3 |
Rep 5,577
though: the car hold 7+ liters of oil and having the oil cooler or line go is a lot better than ripping off or holing an oil pan / crank case cover. Additionally the synthetic oil leaves a surface coating better than conventional oil.
No doubt as soon as u receive an impact you should park and shut off the car. |
